how do you change zero position for B axis (rotary axis, not tilt axis)?
I have a vice on the trunion which isnt aligned with X and Y, because T-slots on the rotary table aren't aligned properly, so I rotated it manually and noted the position of aligned B axis in debug mode (raw data-encoder data).
I tried entering that value to parameter 224, but that changes A (tilt) axis zero position.
which parameter does the same for B axis?
thanks
