586,728 active members*
3,243 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Starting out building a cnc table for plasma
    Feb 2004
    427
    Hi every one. Just starting out in cnc . What are the first steps to take in building a cnc plasma table.
    I know that i need a drawing program, i have AutoCAD, then i need some kind of CAD program. Then Controllers stepper motors and the computer that i am workin gon now.
    What programs do you prefer to use are they free or how much to buy. What kind of controllers do i need and what size/power/type stepper motors do i need. I want to make a full size table to cut full sized sheet steel aluminium etc.
    All help greatly appreciated.
    Cheers Apples
    Feb 2004
    62
    I think the best way to get the answers that you want is reading all the posts in the DIY wood routers. These threads are specially useful:
    http://www.cnczone.com/showthread.php?s=&threadid=171
    http://www.cnczone.com/showthread.php?s=&threadid=646
    http://www.cnczone.com/showthread.php?s=&threadid=1355
    Then you will be able to answer your own questions, and with a good adquired general CNC knowledge as a bonus .
    Hope it helps
    /U
    Nov 2003
    299
    Plasma cutting requires much less precision than carving/milling. You won't need a ridged table for plasma. My suggestion is to design a system with speed in mind. Shoot for 300-400 IPM depending on the capacity of your plasma machine. Accuracy of .005+ should be fine. You may want to build a two axis machine and just drag the torch over the work if you’re not doing a lot of cutting with it. You could save yourself from having to build a Z axis.
    However, if you’re doing production work you may want a Torch Height Control (THC). Keep in mind you will need a Z axis to move the torch up/down. Mach2 software can control a THC. Check out www.campbelldesigns.com for a DIY THC.
    PS. If your thinking of making a “Do-It-All” CNC machine routing/plasma/milling, you should seriously consider making a two separate machines. I tried to combine wood routing and plasma cutting into one machine and had little success. The similarities of the two processes are few and far between. IMO
  1. a million questions about starting cnc
    By Data in forum Uncategorised MetalWorking Machines
    Last Post: 04-14-2008, 05:49 PM
  2. Building CNC Surface grinder - whole lotta questions
    By rashid11 in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2006, 09:53 PM
  3. CNC Drill driving the milling table
    By Com in forum Vertical Mill, Lathe Project Log
    Last Post: 04-04-2005, 09:27 PM
  4. Cost / Price of a DIY CNC table.
    By Havic in forum DIY CNC Router Table Machines
    Last Post: 03-01-2004, 09:08 PM
  5. Help? First attempt at building CNC table
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 04-22-2003, 07:16 PM
