587,597 active members*
4,283 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Orient Spindle For Broaching
    Oct 2013
    15
    We have an HP4000 Horizontal Mill that we are needing to do some broaching on. I don't really want to get into the whole "You should/shouldn't do that on a milling machine....etc." My boss wants to try it and it's his machine. Anyway, does anyone know if there is a way to orient the spindles on these machines to a certain degree? I need to broach 4 square corners 90 degrees apart. I've tried "M19 Rxxx." which works on the Haas machines, but no go on this one. Any input/ideas? Thanks.
    Jun 2004
    511
    Re: Orient Spindle For Broaching
    Try M19 S___
    Oct 2013
    15
    I'm on another job right now, but will give that a try when I go to that operation. Thanks for the input.
    What is the controller type? You need to run the spindle as a C axis in order to do this. I don't know if your machine has that feature setup on this machine or not.
    Oct 2013
    15
    Quote Originally Posted by drdos View Post
    DrDos,
    The control is a Fanuc 31i. I know for a fact that it doesn't have C axis capabilities. Our Haas doesn't have a C axis, but you can orient the spindle to whatever degree you want to. Thanks for the input.
  1. spindle orient
    By nitemare in forum Daewoo/Doosan
    Last Post: 03-14-2013, 05:30 PM
  2. 2nd spindle orient
    By 1234567 in forum Mori Seiki Mills
    Last Post: 08-29-2012, 05:53 PM
  3. Spindle Orient
    By molassesbros in forum OKK
    Last Post: 09-11-2010, 10:35 AM
  4. Help with spindle orient
    By SIERRAMACHINE in forum Fadal
    Last Post: 03-10-2009, 09:36 PM
  5. M19 Spindle Orient
    By ragman in forum Fanuc
    Last Post: 04-01-2008, 11:16 AM
