587,693 active members*
3,697 visitors online*
Results 1 to 7 of 7
    May 2015
    13
    Milltronicas vm 17
    good. Someone can tell me what the gas to electrivo frame radiator cooling Milltronics vm -17.
    greetings
    Oct 2008
    427
    Re: Milltronicas vm 17
    I'd like to help, but I don't understand your question.
    Can you describe your problem more completely?
    May 2010
    54
    Would it be R-22 in the cooling radiator?
    May 2015
    13
    Quote Originally Posted by ZZZZ View Post
    The cooling radiator electric frame that gas does it take?
    Jul 2010
    548
    I still do not know the answer to this question.
    Were the coils damaged???? and you need to repair, or is this a theoretical question????
    sportybob
    Sep 2010
    529
    He's asking if there is freon of some sorts in those coils, is it actually refrigerated or is it just an air to air cooling coil? I'm guessing he's not getting a "cold" coil and suspects his freon has leaked out and wants to know if it's r12, r134, or whatever....
    Oct 2008
    427
    I believe that heat exchanger is Milltronics part number MA-148.
    The coil should have 4oz/113 grams of R-134A Refrigerant in it.
    Here is a link to the catalog (I think):
    http://www.hoffmanonline.com/stream_...32&pRID=308029
