587,489 active members*
3,060 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Extruding Trouble
    Apr 2003
    89
    Extruding Trouble
    I'm having trouble with the results of extruding a polyline.
    When a polyline is extruded you get a vertical line at every point on the polyline ( left hand shape)
    I don't want these small vertical lines at each point.
    I tryed drawing the shape useing splines which avoids the points but cannot be extruded.( right hand shape)
    In short any ideas how to avoid the short vertical lines at every pt. along a polyline when it's extruded?
    Thanks all.
    Those vertical lines are only in the display, not the model itself. Go to Tools>Options, on the Display tab, check Show Silhouettes in Wireframe. When you HIDE, they should disappear. Also, you CAN extrude splines, you just have to make them a region first. Type REGION, select all the objects that make up your extrusion profile, and hit enter. Your profile will now be a region which can be extruded..
  1. Trouble with end mills?
    By Durkee in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-27-2007, 03:53 PM
  2. Router motor trouble
    By jabba in forum Commercial CNC Wood Routers
    Last Post: 06-23-2005, 04:09 AM
  3. Replies: 3
    Last Post: 05-31-2005, 04:41 AM
  4. having trouble getting this to cut right
    By MIKENLN in forum BobCad-Cam
    Last Post: 04-19-2005, 08:24 AM
  5. Tool holder trouble
    By an0n in forum Uncategorised MetalWorking Machines
    Last Post: 04-06-2005, 04:43 PM
