587,492 active members*
3,624 visitors online*
Thread: VMC Thoughts
    Oct 2014
    38
    VMC Thoughts
    Gentleman I seek your knowledge please; I am looking to buy a CNC machine to work with aluminum 7075 and steel 4140. Initially I was thinking of a Tormach since I want to spend around 10K however I been reading through the forum and for what I can put together I am better off just buying an used VMC, hopefully a bit of a fixer upper with tooling, I am willing to put the time to rebuild the machine and stretch out some $.
    I have time to get it working is not something that I need for production, I am in no rush.
    I am thinking of a Fadal, Haas or Japanese made CNC, something with linear ways, easy to service, with problems that I can fix with a bit of time, probably a 1995+. What brings me to the questions.
    I am correct to be more inclined to getting a Fadal?
    How many hours of usage should I look for?
    I can't get 3 phase to my home so easiness to get it to work with single phase is a plus, so I would love to hear your recommendations.
    My ceiling in the Garage is 9'3" however the actual garage entrance is 7' is this going to be a problem? Or is it easy to remove anything that is poking past 7" to make it through?
    I would like to keep the machine as small as I can (I know they are as big as a car or bigger), what do you guys recommend, should I worry about this?
    I been looking locally in Creigslist and checking online auctions like in Bidspotter.com | Industrial, Commercial, Plant and Machinery auctions and MachineTools.com, The metalworking machine & tooling marketplace for new & used equipment., however I do not feel very comfortable buying from out of state without being able to check the machine, what do you guys think? Any other places where I could check for a deal?
    I thank you all for any knowledge you can share.
    Feb 2011
    423
    Re: VMC Thoughts
    Where are you located? There maybe a member here that is near you that know of a mill nearby that isnt being advertised.
    Welcome to the zone.
    Aug 2004
    782
    Re: VMC Thoughts
    Almost no VMC will fit in under 8 feet, WITH the top spindle motor removed.
    You need to raise the garage entrance, more is better.
    We fit some small haas machines in, just, at 240 cm == 8 feet, by removing motor and resistor coils, iirc.
    The ones that do fit will cost 2-5x more.
    Very rare/unusual, and higher end machines = $$$.
    Note minimil is 3150 mm in height, spindle up.
    Fadal is a good option, esp. in the US.
    Nov 2003
    287
    Re: VMC Thoughts
    You can get a Fadal VMC 15 under a 80" door, but you have to remove Z servo and cable chain. Isn't very difficult.
    Oct 2014
    38
    Re: VMC Thoughts
    Thank you all for your responses, I am in Las Vegas NV. I do not see too many used CNCs listed localy, the ones I usually see are way to expensive for me. If anyone out there has a cheap VMC let me know
    Good to know that a Fadal VMC 15 will fit by removing the Z servo and cable chain, I'll keep an eye out for one of those. Once more thank you everyone for all the help.
  1. Any Thoughts?
    By miles peters in forum DynaTorch
    Last Post: 11-20-2012, 05:37 AM
  2. CNC to NC Thoughts
    By Fish4Fun in forum Open Source CNC Machine Designs
    Last Post: 03-24-2011, 06:11 PM
  3. Any one have thoughts on this?
    By packrat in forum Benchtop Machines
    Last Post: 01-23-2011, 01:32 AM
  4. Think im going to get a X4... any thoughts?
    By simila95 in forum Benchtop Machines
    Last Post: 04-16-2009, 04:16 PM
  5. CNC thoughts
    By Tekko in forum Benchtop Machines
    Last Post: 02-12-2007, 02:20 PM
