586,655 active members*
3,057 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    May 2005
    240
    Horizontal metal bandsaw for home shop
    I'm looking at something like this to cut my stock and other stuff such as steel angle. I can't justify a more expensive one with all the bells and whistles so I'm wondering if this would get me by and if anyone has had any bad experiences with this class of machine.
    All replies are appriciated. Thanks.
    Aug 2004
    2849
    Works great....I've seen some writeup where people have burned up the motor....I used my all summer in 100 degree weather and always had a fan trained on the motor.....to cut over 300 feet of 1" square steel tubing...changed the blade and speed and cut a bunch of 1" thick Aluminum jig plate...no problem.
    Personally I think it's a good buy....a good quality motor is inexpensive...or buy HF warranty...
    Aug 2005
    90
    I've had mine for 7 yrs. Seems I paid $150.00 for mine. I've cut 6" stainless round bar with no coolant, just turned it on and walked away. The stand is weak (junk) but all in all not a bad buy.
    Robert
    May 2006
    27
    I think a horizontal bandsaw such as this one (same one I started with) is a must-have for the home shop. Most of them have a few minor problems to fix before they operate well, and some have poor quality motors that will run hot or overheat. I bought the HF model, but later got the better motor that Grizzly included on theirs. It no longer heats up.
    You can get by with this size bandsaw forever if you are patient. I finally upgraded to a 7x12 horizontal (cuts far faster) and also a separate vertical saw (for cutting sheet/plate). However, I still use the 4x6 frequently as I keep it equipped with a blade good for cutting smaller and harder material. If I want to cut something several inches thick then of course I use the 7x12.
    If you are still using hacksaws or recip saws or cutoff saws other such options you will be very happy if you get a 4x6. I was reluctant for a while but now realize that was a mistake. Also get some quality blades suited to the pieces you will cut.
    Alan
    Nov 2005
    25
    I've had my 4x6 for 5 years now and fing it works good. Considering I only paid $180cdn for it it was a great deal. The saw paid for itself with the first job I did. The only shortfall was the stand, which I have replace with one much stiffer and a lot higher. If you buy a good bi-metal it will make alot of differance. When you buy it get a tube of stick lubricant, it looks like a tube of grease. You apply the lubricant to the moving blade every once in a while and it cuts much faster and the blades last longer.
    Jul 2004
    601
    I have that saw also. I've found it is impossible to get the blade true to the world (square cuts). I agree the stand is junk. I also had to grind my blade guide, to get the full travel to do some 45 deg cuts.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Oct 2006
    59
    I have one as well and concur with all of the above comments. Just checked the HF web-site (interestingly enough to order a couple spare blades) and it is currently on sale for $179.99.
    Justin B.
    Aug 2004
    2849
    Forgot to mention the dri-lube....I use the Boelube in a tube....makes a difference.
    Oct 2004
    84
    I have a Wells saw at home with coolant, but seldom bother mixing up a batch of coolant for small jobs. I spray the blade with WD 40. I buy WD 40 (or, as my wife calls it, DW40) by the gallon and use a hand squeeze spray bottle.
    We have a much larger saw at school and I tell the guys I usually feed slower than they do simply because I have to pay for my blades at home. That message doesn't seem to impress them. About once a week we hear the saw lock a piece of broken blade into the stock which then it acts like a hardened cutting tool to rapidly remove the rest of the teeth from the blade. This produces a blade that, were it stainless, might be good for shredding lettuce at Taco Bell.
    Nov 2005
    25
    The last company I worked for it was my responsibility to ensure the engineers were trained on using the equipment and to make sure they worked safely. What I would do is buy carbon steel blade stock by the coil and if they didn't listen and broke a blade they got a leson in welding a new one. After several attempts at welding the blade eventually they got it and learned that the hard way to listen especailly when you have 3 or 4 people standing there waiting.
    Feb 2004
    361
    The cheap import saws are pretty good, everything considered..been running a 4x6 for probably 20 years now, maybe three of four sets of bearings, again cheap Ringball brand or equivalents, same motor , set on middle set of sheaves...
    Usually run the cheap blades as I abuse them a bit [ok, sometimes a lot], and just replace when they lose teeth or angle cut.. for better cuts I get the bimetallic blades...
    No coolant, [except for aluminum], and a fair bit of pressure, the tension spring loosens up when I lift the arm more than six inches..
    Only thing I noticed with the cheap blades and higher than recommended pressure is that they occasionaly break at the weld..
    still haven't changed bushings, lots of regular greasing, and the gearbox has that black moly Polaris chain case oil in it now, handy when I'm cutting at 20 below...
    Oct 2006
    59
    It's now even cheaper...
    Interesting, this discussion of the cheapo saw. The Harbor Freight flyer I received this past week shows it's now on-sale at your local store for $159! I now feel ripped off by buying mine on sale for something like $197. But, after cutting a chunk off some 4" wide x 1/2" 4140 stock (for the four bolt clamp mod for the 9x20) with a hack saw convinced me that it would be worth double the price! I think I went through 6 "Buck" brand hacksaw blades on that project...
    Dec 2005
    390
    I have one of these saws and it does a good job but it currently less than half of the original saw remains. For aluminum I use a sliding compound miter saw ($180 or so from HF) with a carbide blade - cuts faster, deeper, and wider than any bandsaw I could afford. For steel I often use a chop saw.
    May 2005
    2502
    These saws are a fantastic bargain for the money, but I have basically quit using mine since I bought a DeWalt Multicutter. It's sort of a poor man's cold saw. Cuts everything the bandsaw did much faster, smoother, and with less fuss. It's a little more money, but still not a very expensive tool.
    Best,
    BW
    Jul 2005
    12177
    Two posters have mentioned "cuts faster" with regards to an alternate choice. Don't you ever want an excuse to sit down for twenty minutes with a nice cold beer using the excuse "the saw is sooooo slow"?
    Dec 2005
    390
    This is the saw that I cut Al:
    http://www.harborfreight.com/cpi/cta...emnumber=91852
    Sounds a little nuts initially but works well. I don't like pulling it forward while in the material because it tends to grab and want to move too fast. Instead, left the head up, move forward a little and then lower the head back into the material. Clean cuts and can handle good sized pieces.
    May 2005
    2502
    Quote Originally Posted by Geof View Post
    Well since I'm the boss, I can take a break any time, so no, don't wish for that. The other problem tends to be that the saw is at the beginning of my workflow, so it holds up the more interesting work anyway. Now a vibratory deburr is something I could see taking the role of calling for a beer break once loaded.
    Best,
    BW
    May 2006
    27
    The DeWalt DW872 certainly looks like a nice saw, but is only rated for 2 9/16" solid stock and presumably requires manual feed. Quality blades appear to cost over $100 as well.
    Alan
    May 2006
    27
    I just noticed this saw over at J&L: http://tinyurl.com/ydrjss
    Only $110 for a 4x6 of uncertain quality.
    Alan
    May 2005
    2502
    Quote Originally Posted by Alan Wright View Post
    Alan
    There would be no point to a power feed, the cut is all over with so quickly it hardly matters. I've cut everything that fits in the darned thing with no issues. I certainly have no doubt it'll cut anything my 4x6 bandsaw would.
    If you do buy a 4x6, be sure to buy a good blade for it. The other thing I'd say about mine is it worked great, but it was a little fussy to keep happy. Blade popped loose and that sort of thing. I would discard the cheap sheet metal stand right away. I saw someone had theirs mounted on a nice rolling tool table:
    If I were still using mine, that would be a must. The more rigid cart would make it nicer to use, and you'd gain some storage underneath.
    The other comment I'll make is we had a nice larger industrial model at the local community college shop where I learned to weld. Other than capacity, it had no advantage over my smaller saw. A lot of guys go crazy trying to get the hydraulic feed, but I like the spring better myself. Adjust for just enough but not too much pressure and get used to just letting the saw run.
    There is a Yahoo Group about these saws that has lots of tips:
    http://groups.yahoo.com/group/4x6bandsaw/
    It's worth a glance through. I still prefer my DeWalt though, all things considered. I may convert the bandsaw to vertical-only operation and use it for contouring rather than cutoff.
    Best,
    BW
Page 1 of 2 12
