Hi i have an issue with mach3 as far as i can tell.
mach3 .62
Ethernet SmoothStepper
MB-02-V6 bob from Homandesigns
gecko g320x
if i run a simple gcode to go from X0 to X250 to X0
it will over run X0 IE it will be X-1
depending on speed at full speed it will be out by about 10mm.
i have changed the pin on the bob from 2,3 to 8,9 no change.
if i go to port and pins and change to active high it goes the other way IE x10.
i was looking at the G320x when it moves and both lights stay on.
if any one has an idea what this is please let me know.
Andrew
