587,125 active members*
5,029 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > The xyz axis of the machine can be moved only when we press the OT key
    Mar 2013
    12
    Dear Sir,
    I have an older laser Fanuc 0-L Control Amada Laser LCV-6510 II. The xyz axis of the machine can be moved only when we press the OT key. But the 4th axis is normal.There is no alarm message on the screen.+ -X Y,Z and interlock message ,md1-4 ,In–position check signal is normal . Could you kindly give me any advice ?
    We would be very grateful if we could receive your reply!
    Yours sincerely ,
    huta
    [email protected]
    Aug 2011
    2517
    Re: The xyz axis of the machine can be moved only when we press the OT key
    check X Y Z axis end-stroke switches. at least one of them is stuck in.
  1. Matsuura MC510VS with Yasnac 3000G control all axis drop out when moved too fast
    By alanbredbury in forum Uncategorised MetalWorking Machines
    Last Post: 06-26-2013, 06:05 PM
  2. Deawoo puma 2000sy y axis moved-.08?
    By 28jalopy in forum Daewoo/Doosan
    Last Post: 05-06-2012, 07:39 AM
  3. Y axis is starting out moved over for each new Z-level cut
    By OneAndy in forum LinuxCNC (formerly EMC2)
    Last Post: 10-21-2008, 02:22 PM
  4. Replies: 6
    Last Post: 08-01-2006, 03:37 PM
