586,682 active members*
2,621 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc O-T control axis can't move backward
Results 1 to 13 of 13
    Apr 2008
    44
    Our CNC turning machine got problem on axis Z
    machine no alarm, but axis Z can't move backward ( + ) direction even in manual or auto mode
    machine only can move on forward ( - ) direction only
    I was change encoder, check limit switch over travel, extend parameter savety over travel
    unfortunately machine still problem
    Any body can help me please
    Dec 2006
    13
    Re: Fanuc O-T control axis can't move backward
    You can shut down the control,then restart with the "P" and the "can" keys held in until it reboots.This over rides the travel limits and permits you to move. Best to turn control back off and restart normally to reset the limits.
    Apr 2008
    44
    Quote Originally Posted by anr.red View Post
    Thanks for your suggestion,
    by the way press P and Can during reboot not effect in memory NC..?
    I just worry, if press P+Can+ NC on..it will be erased memory NC
    Thanks for your attention
    Dec 2006
    13
    It won't affect anything,just overrides the limits
    Apr 2008
    44
    Press P+Can and reboot the machine
    unfortunately machine still problem, can't move back ward
    any other advise..?
    thanks for your attention
    Dec 2006
    13
    If you have a presetter for tool offsets,the contact may be stuck or shorted,check the one for the axis and direction not working.
    Oct 2015
    11
    go to the setting you need to set a zero again on parameter and make a new zero return....
    Aug 2011
    2517
    this is a common problem caused by a stuck or non-functional deceleration switch somewhere. you need to check all Z axis switches at BOTH ends of the stroke limits.
    Apr 2008
    44
    Machine is incremental encoder
    Limit switch was check all normal
    now Z and X axis can't move backward
    Oct 2015
    11
    set a zero origin again
    Sep 2015
    Hello,
    Did you fix it ? I’m having the same problem on a fanuc otc. I can’t turn the x axis in + direction. Just in - direction.
    I’ve tried everything and the tech guy replaced the axis card on the controller and nothing . Any help is appreciated
    Aug 2016
    6
    Hello,
    Just wondering if you got this fixed....I have the same issue sometimes on the Z axis. I usually wait half an hour to an hour and it starts to move again....annoying.
    Hello good time
    Is your problem solved?
    Thank you for your advice
  1. Z axis won't move under program control
    By Mike4703 in forum Mach Mill
    Last Post: 04-20-2020, 11:19 AM
  2. How to setup JOG control to move 2 axis with each direction key
    By MickPaul in forum Mach Wizards, Macros, & Addons
    Last Post: 06-29-2013, 12:06 PM
  3. Replies: 6
    Last Post: 06-22-2011, 08:30 PM
  4. Replies: 1
    Last Post: 03-18-2011, 10:25 AM
  5. Rapid move axis control
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-15-2008, 03:51 PM
