587,511 active members*
2,972 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
    Nov 2011
    12
    Description
    I am selling this Emco Compact 5 CNC automatic tool changer. It was pulled from a working unit and fully tested.
    The mounting bolts ARE NOT included.
    It can hold up to 6 tools.
    It comes with 2 carbide inserts holders
    It is in good condition and working perfectly.
    It has some cosmetic flaws in the paint and some oil and oxydation stains.
    Perfect for homemade lathes or retrofit.
    If you're buying this for a homemade lathe, you will need a 12 VDC regulated power supply to make it run.
    The polarity determines whether the tool holder is turning or in locked position.
    List Date: 2/8/2015
    For more info, click here to view the original listing: Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
    This item is no longer available.
    Mobile friendly version: Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
    Go Mobile: Download the free Panjo iOS app now!
    Jan 2014
    Re: Emco Compact 5, PCTurn 50 55 Lathe Automatic Tool Changer 12 VDC
    Is currentl y for sale ?
  1. lathe automatic tool changer(turret)
    By valmet58 in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2014, 07:09 PM
  2. Automatic tool changer program for a 8 tool turret Diy lathe cnc
    By tessen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2014, 05:05 AM
  3. emco compact 5 - lathe tool holder series??
    By NoviceLatheMan in forum EMCO Lathe
    Last Post: 01-27-2011, 06:33 PM
