587,794 active members*
2,910 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > need to avoid " chuck clamp confirmation "
Results 1 to 19 of 19
    Jun 2015
    4160
    Hy guys, about lb3000ex2 lathes
    1) i need to use the S axis with low hidraulic pressure, below 0.5 mpa. Problem is that machine does not start, because it thinks that the chuck is unclamp. In reality, the chuck is clamped, but the machine does not receive confimation below 0.5 mpa.
    2) i need to use C+M axis without hidraulic pressure.
    of course, i can do both things using normal pressure, but it would take longer ...
    meow-meow the world kindly !
    Aug 2004
    782
    Re: need to avoid " chuck clamp confirmation "
    Add extra IO to sensor with a manual switch ?
    Then use it to cheat the machine.
    Think of safety aspects.
    I am not at all sure you really want to do this ...
    If the part lets go, death and dismemberment are a real possibility.
    Of course, we have no idea of your experience, but if you need to ask, this is NOT somthing that is safe imho.
    Jun 2015
    4160
    Quote Originally Posted by hanermo View Post
    i didn't understand what you mean ... please, can you be more explanatory ?
    ) yup, safety comes 1st
    Jun 2008
    372
    Can you adjust the chuck confirm sensor at the back of the chuck cylinder? If your machine is CE spec then it is very difficult to get around this error
    Aug 2011
    423
    Did you try M184 code?
    Apr 2009
    1262
    Like they say, i'm not sure why you want to do this and it does require you to be running in a safe manner. The prox switches still need to be met with only one on at a time. You can adjust the pressure sensor switch to a lower value by removing the plastic cover in the center and then adjusting it with a screwdriver. It should be set to about 100 psi from the factory as a minimum pressure. They do this because the chuck itself starts to drastically lose gripping force below that value. Many factors start to come into play at that point such as grease being used, cleanliness of the chuck slides, RPM of chuck, workpiece weight, etc.. Be sure to be safe. Remember "without hydraulic pressure" means without gripping force and that is why they set a minimum. If you are distorting your part it is better to surround your part more fully with pie jaws rather than lower your pressure to reduce the distortion. You will also need to reduce your cutting forces as your gripping force reduces. If you tap on the workpiece with a soft hammer, you will see how easy it becomes to move the part once you reduce your pressure, so once again be careful, you are choosing to do what is not recommended.
    Best regards,
    Jun 2015
    4160
    hy all, thx 4 answers
    1) low hidraulic pressure
    i did not mess up with the sensors, because i don't know how ..
    M185/M184 does nothing : when compiler reaches this line, machine stops without error - so, it does something,but it does not work
    I used a reamer ( static part + rotating tool ) to calibrate a hole, but chuck pressure, even at 0.5mpa, is too big. Control caliber does not fit when part is on the machine, but it fits when part is taken out
    Jaws stamp is good ...
    Well, sometimes is tricky to use drills and after that reamers, when holes are long and walls are thin, because reamer gets strangled by hidraulic.
    Same tools worked nice on a classical lathe ...
    If i just could set the hidraulic pressure right.
    Anyway, i use a knife instead, and it worked.
    * knives : speed
    * reamers : cilindricity
    In this case i used a knife because hole was not so long; reamers are more suitable for long holes than knives.
    When holes are long, and jaws are clamping them, things get ... meow-meow
    2) no pressure at all
    I needed to mill the jaws, so after that to clamp and turn them ... so, i send them to a mill, or i improvise some kind of a clamp
    Well, beside those sensors, is there a way to avoid hidraulic pressure confirmation ?
    kindly !
    Jun 2008
    372
    On a CE machine the pressue switch needs to be confirmed for the machine to run. You could put the machine in "adjust mode" and over ride the PLC input for the pressue switch, but this is not recommended as a solution
    Jun 2015
    4160
    Quote Originally Posted by budgieW View Post
    sounds nice ... do you think i can do that ? ... do you have a manual 4 that ? i am not a PLCguy
    Sep 2015
    17
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Is there a proper technique/method to setting the proximity sensors? One of the sensors on our chuck has moved and needs to be set properly. I attempted to reset it, but it's still alarming out. Thanks in advance!
    Jun 2015
    4160
    hi nicu, there should be 2 proximity senzors; screwdriver / allen & next table / kindly
    Code:
        chuck                 |         senzor
        set for od clamping   |   left   right    (*1)
        open                  :     o             (*2)
        closed on part        :     o      o
        closed without part   :            o      (*3)
      *1 : looking from the back of the machine
      *2 : " o " means " ligths on "
      *3 : normally, in this case, you should receive an error
    Apr 2009
    1262
    Simply put, you can only have one ON at a time. The switches reverse meaning when changing from OD to ID chucking.
    Experience is what you get just after you needed it.
    Jun 2015
    4160
    hy mr wizard when chucking, both lights are on
    empty ( or chuck grasp ilk cancel ) & empty miss clamped : only one / kindly
    On a CE machine the pressue switch needs to be confirmed for the machine to run. You could put the machine in "adjust mode" and over ride the PLC input for the pressue switch, but this is not recommended as a solution ...
    because it may mess up the bearings inside the hydra cilinder
    Jan 2013
    126
    Have you thought about using a fixture?? Or if the part is small enough you could us a collet fiture ore a collet chuck
    Apr 2009
    1262
    Oh I remember possible trick style. Changing to air chuck will ignore switches in favor of timer for clamp unclamp. Default 5 seconds. Of course be careful as before.
    Jan 2013
    126
    This will also get the desired extremely light clamping you desire as well.
    Jun 2015
    4160
    hy mr wizard, so far i did not seen an air chuck at work; i was believing that there is also a pressure confirmation ... time delay is ok, but a low air pressure ( accidentaly ) may ruin the setup; or maybe there are some pressure senzors, at least before the air gets inside the machine ... i would be more comfortable knowing that also the pressure inside the chuck is monitorized
    Apr 2009
    1262
    I don’t believe that the air pressure is monitored by pressure switch. Thus it should work in your situation.
    Please try doubtingkitty..,
    Best regards,
    Jun 2015
    4160
    hello, i was looking through special functions, when i found something designed for monitoring air : i don't know if it checks pressure value/range, or only pressure presence, but maybe there is an adjuting valve ? also, i found a parameter for the alarm type; pls check attached
    it may be a good idea to monitor air pressure for an air chuck, so to avoid " system fly by "
    recently we used diy air for a setup, so to blow the chips away / kindly
  1. Adjust gantry to avoid "racking"
    By Brian@Premier in forum Uncategorised WoodWorking Machines
    Last Post: 02-26-2014, 03:17 PM
  2. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. What is the difference between "clamp" and "brake"
    By BorislavS in forum Uncategorised MetalWorking Machines
    Last Post: 02-05-2013, 04:59 PM
  5. Cheapest place for a Bison 6-jaw chuck? 8", 10" and 12" ?
    By squale in forum MetalWork Discussion
    Last Post: 10-13-2008, 01:00 PM
