587,829 active members*
2,989 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Need Parameters and possibly EEPROMS
Results 1 to 7 of 7
    Sep 2012
    106
    So I had a tech come and look at the machine. Its a 1989 Kitamura Mycenter 2 OMB. Said something in the Parameters was off, even thought I have the ORIGINAL papers from Kitamura. I have an OM-B control, 20 tool changer. I need to see if the ladder in the ROM is bad, or if the ROM chips (EO1 and EO2) are bad and need to be replaced. The machine turns on, goes into ready, but when I turn the TEACH/EDIT/MDI switch, nothing happens. Anyone have this machine and a set of parameters? Or anyone able to burn a set of ROMS and I can paypal you? I need this machine back up months ago!!! Nobody seems to know how to fix it.
    Sep 2012
    106
    Re: Need Parameters and possibly EEPROMS
    Aug 2011
    I have it.
    Aug 2011
    I could help you. I have parameters , diagnostics and backup of OE1and OE2.
    Sep 2012
    106
    How can I get a hold of these from you hashemireza? I have the techs with the fanuc programmer coming out on Tuesday to try to modify my ladder again.
    Sep 2012
    106
    I have parameters and some diagnostics, but they retyped my ladder in type M, and I need it in type L.
    Dec 2022
    11
    Having a kitamura mycenter 2x 1997 with yasnac I80M controler i loste all paramaetres including offset,macro.common and aux2 data.
    Anyone can help ill be soooooo thankful.
  1. Replies: 2
    Last Post: 06-26-2014, 02:07 PM
  2. X,Y and possibly Z
    By cdngunner in forum DIY CNC Router Table Machines
    Last Post: 01-09-2012, 02:35 PM
  3. 4 x 8 laser possibly...
    By Dubliner in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-11-2010, 03:44 PM
  4. possibly FS: 60.000 RPM spindle w. ATC
    By dar303 in forum PCB milling
    Last Post: 10-20-2010, 02:59 AM
  5. x2 potentiometer possibly bad, help
    By h_2_o in forum Benchtop Machines
    Last Post: 12-13-2006, 05:18 AM
