587,459 active members*
3,612 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Absolutely DESPERATE for Help. Shenhui Laser...Laser power not coming on.
    May 2013
    23
    Hi there,
    So I was cutting a stencil yesterday and half way thru the job, the power for the laser stopped. The axis and control seems fine tho. I checked and changed the fuse....Nothing. I swapped out power cords....Nothing. I've sent a couple messages to the China mfg'er but with the time difference, it'll be monday hopefully, that I get some help. The laser tube is suppose to get around 3000 hours/3 months. We've been using for over a year about the hours aren't close to 3000. If the tube is spent, would that stop the power itself from coming on? Really needing some help with this as I have jobs piling up now.
    Thanks in advance,
    JeffClick image for larger version.
    Mar 2015
    79
    Re: Absolutely DESPERATE for Help. Shenhui Laser...Laser power not coming on.
    Did you check your water flow and door safety switches.
    Time to get a meter out and start a little troubleshooting.
    Start with the obvious. I don't know your controller but some have indicator lights to help let you know what's going on.
    It could be a loose connection. Just kind of check it out slowly but make sure you power it down. Safety first, always.
    I don't think most tubes just die all of the sudden. You would likely see it start acting up first.
    Some units have 2 switches. One for the controls and axis movements and another for the laser power supply.
    See if you are getting power to the laser power supply. Start at the switch and go from there.
    Good luck and I hope you find it.
    Gozzie
    May 2013
    23
    Thanks Gozzie,
    Correct with the two switches.The one for the controller and axis movement is on and working but the laser power switch doesn't come on. I will get a meter and start checking. The hours on the tube is only around 1000. The vendor said I should get around 3000 hrs and yes, I would think it wouldn't just die all of a sudden. Hoping for the loose wire :-). I will post once figured out.
    Thank you.
    Apr 2004
    475
    Obviously, check all the fuses too!. Does the power supply have any lights? If yes, does pressing the test button on the supply do anything?
    Sep 2012
    212
    Hi, Jeff,
    Follow this video to confirm whether it is tube problem or the powrsupply problem.
    Laser tube problem or Laser powersupply problem - YouTube
    If powersupply problem, contact the vendor for exchange, if tube problem.. ur.. it seems the tube is already out of warrety.. so you can only think about buying a new one.
    Melody
    G.Weike Laser
    [email protected] [email protected] skype:melody.gweike
  1. Do you have a Shenhui Laser? Looking for support....
    By ClickDraw in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-12-2015, 10:13 AM
  2. Shenhui Laser
    By hackahobby in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-19-2013, 01:02 PM
  3. Shenhui or WK Laser? Your Suggestion?
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-29-2012, 03:35 AM
  4. Help Needed!!!! Shenhui Laser K40
    By cheethr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-05-2012, 09:48 PM
  5. SHENHUI LASER
    By romuros in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-16-2012, 08:45 AM
