587,236 active members*
3,645 visitors online*
    Oct 2013
    64
    Haas control.
    Anyone knows how to deal with problems with haas super vf2 control?
    Mar 2010
    1852
    Re: Haas control.
    Seriously!
    Oct 2013
    64
    Re: Haas control.
    Whan i push prog list i hear a load bang noise came out of atc (i think) then the keyboard stop responding and i have to power off the machin in order to carry on working. I cant choose another program other than the one that is working.
    Mar 2007
    23
    Re: Haas control.
    This is common issue with older Haas controls. Problem is file names on your hard drive, the control does not like long file names (longer than 8+3 characters) or letter else than 0-9 a-z A-Z.
    Sadly only way to recover from this is to reload the control software. I have done it numerous times in past for this reason (before we figured out what was happening). Reload process is rather simple but you need to get proper files and instructions from your HFO service guy.
    Oct 2013
    64
    Re: Haas control.
    Yes the haas service guy did use some files i had reparing it. Thank you.
  1. Haas dt1 control
    By Bgeise in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2015, 02:37 PM
  2. New Haas control help please
    By hercules in forum Haas Lathes
    Last Post: 07-28-2009, 04:52 PM
  3. New Type HAAS Control
    By Ginger_Ninja54 in forum Haas Mills
    Last Post: 02-19-2009, 12:47 AM
  4. haas rotary control
    By heartlnd in forum Haas Mills
    Last Post: 02-04-2007, 09:46 AM
  5. Haas TM-2 Mill Control
    By Malish in forum Fanuc
    Last Post: 06-27-2006, 03:54 AM
