587,025 active members*
3,347 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Again, crusader M, servo disconnect in rapid
Results 1 to 7 of 7
    Jan 2008
    41
    Ok ,once again I need help with the z axis tripping the servo disconnect when using rapid moves. I had this problem once before, the servo drive board was replaced and the problem was solved. When it started this time, I thought I could just replace the board again. NOPE. Bought a couple boards off e-bay, changed the board, problem remains. Changed the transformer under the drive board. problem remains
    I verified the problem is just on the z axis, by switching the y axis wires to the z axis board. Servo disconnect trips when a rapid move is made. It does fine with a feed move or jog moves.
    The machine is an Anilam crusader M (1989) on a Supermax mill 3 axis.
    I could program feed moves instead of rapids, for now. but a lot of the canned drill cycles use rapid moves in z.
    Any Idea what to look at ?
    Van
    Feb 2009
    6028
    Re: Again, crusader M, servo disconnect in rapid
    This machine use tach feedback off the motor? How's the encoder signal look off the Z motor?
    Jan 2008
    41
    uses glass scales.
    Feb 2009
    6028
    Still has feedback from the motor, either tach or encoder. Has to, the drives need velocity feedback not just position.
    May 2006
    21
    I have two crusader m's and both don't like trying to rapid z over 150ipm and 200ipm on X Y Anilam put out a bulletin on how to set them
    and it went like this: 70000249 service doc. The program format as follows:
    1) V01 200. V01 = XY Rapid Rate.
    2) V02 150. V02 = Z Rapid Rate.
    3) AUX 1440 AUX 1440 = ACTIVATES NEW RATES.
    4) END
    This program will set XY axis to 200 I.P.M. and Z to 150. This should be entered and run as a program in memory. These values must be re-installed after a 'cold boot' of the system.
    hope this helps
    Jan 2008
    41
    Well after changing the servo drive card, the counter board(black tab), with no improvement. I'm ordering a new encoder, for the z zxis.
    I'll keep you all uupdated.
    Jan 2008
    41
    That's what was needed, new encoder installed, problem solved!
  1. Help with Anliam Crusader 2 Servo transformer
    By want-to-be-cnc in forum CNC Machine Related Electronics
    Last Post: 12-23-2013, 11:48 PM
  2. Servo Error 447 y axis hard disconnect.
    By jimmy111 in forum Fanuc
    Last Post: 11-13-2013, 04:44 PM
  3. Crusader 2 servo motor question
    By seasicksteve in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2012, 01:21 AM
  4. G320 - Wire disconnect from servo while operating
    By Ashley Cobb in forum Gecko Drives
    Last Post: 04-03-2010, 02:52 PM
  5. SERVO DSCNT error on Anilam Crusader M
    By p27182 in forum Uncategorised MetalWorking Machines
    Last Post: 09-17-2009, 12:39 PM
