586,744 active members*
6,061 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Checking DC Bus voltage on MagneTek drive
    Mar 2010
    1852
    I have a spindle drive on my 97 Haas VF-2 that may be bad, it's a Magnetek GPD 515. I have the manual and it says to check the bus voltage at display U1-07, but I can't seem to get to that display. I found U1-01 thru U1-06 but then it goes to some other place rather than U1-07. I need to check the voltage before sending out for repair.
    Thanks is advance-----Mike
    Mar 2010
    1852
    Re: Checking DC Bus voltage on MagneTek drive
    Found the terminals on the drive unit. (4 and 5 from the left) Voltage is good, so off for repair.
    Mike
    Mar 2010
    1852
    I sent my unit to Zaritron, LLC on Monday and had it back and installed on the machine by Thursday afternoon. Highly recommend Zaritron, LLC in Illinois.
    Thanks---Mike
    Mar 2015
    10
    Quote Originally Posted by Machineit View Post
    Thanks---Mike
    Thanks for the source. I assume this was to fix a 123 alarm? Issues during spindle accel or decel? Or something else?
    Mar 2010
    1852
    Yes, it was 123 I believe. Spindle Drive Failure. Drive showed DC Buss Undervoltage. In the end, the spindle would not even try to turn, it would just alarm out. I check out is site more and he works on all drives and circuits it looks like.
    Mike
  1. Chopper drive max voltage vs max voltage of Nema23
    By K_G_B in forum Stepper Motors / Drives
    Last Post: 07-11-2014, 04:17 AM
  2. Num servo drive - onder voltage
    By flannman in forum DNC Problems and Solutions
    Last Post: 04-20-2009, 09:38 PM
