586,847 active members*
2,453 visitors online*
Thread: Hoss 5C 7x10
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Re: Hoss 5C 7x10
    2000 would be plenty.
    Hoss
  2. #22
    Aug 2008
    1186
    Re: Hoss 5C 7x10
    Very cool! I wound up just going with the new spindle for a 4" chuck. I was not certain I could get the headstock machined properly. I ordered up some ABEC-5 7206B 2RS AC Bearings from china.. Not sure they will actually be that Precision, but they were only $16 each and I'm having them shipped with my 8mm and 12mm ground ballscrew and bearing support blocks.
    I think I want to machine a new carriage to extend the X travel and reverse it so I can set it up like a little slant bed Lathe with a 6 position tool turret like the emco uses.
    I am just about done drawing everything up in solidworks. And saw I can buy cast iron blanks from speedy metals online.
    I am going to add a linear rail on the backside along the length of the bed as a cantilever support for the extended carriage to support the turret. I have a feeling this little lathes is going to become a freak like your X2..lol. I may order a 16" travel bed from LMS and if I do that I may use the existing bed tied to the back to better stabilize a longer z carriage.
    I'll post up models when I sort all the ideas out..
    Sent from my XT1080 using Tapatalk
  3. #23
    May 2004
    7
    Re: Hoss 5C 7x10
    Hoss,
    do you recall the part numbers for the bearings and lock nuts?
Page 2 of 2 12
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Hoss's 3D Printers
    By hoss2006 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-27-2015, 04:05 PM
  3. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
  4. Hoss Conversion Well Under Way
    By mrcodewiz in forum Benchtop Machines
    Last Post: 03-31-2008, 09:44 PM
