586,750 active members*
7,452 visitors online*
Results 1 to 10 of 10
    May 2004
    15
    Rapid moves G00
    Does anyone know how to slow down rapid moves. G00?
    I tried tuning my stepper motors in mach2 but had no luck.
    I'am using hobby cnc controls on one mchine and stepper world controls on my other machine. My stepper motors just can't handle rapid move. They screem. To fast.
    Rapid moves are performed at the velocity in the motor tuning screen. Lower the velocity in motor tuning to slow down G00 moves.
    May 2004
    15
    Thanks gewr21.
    Apr 2005
    3634
    Gerry,
    Will Mach3 let you control G00, line by line with different "Feed" values in the g-code (program)?
    Jerry
    No, because G00 doesn't use a feed rate. There is a rapid overide on the settings page, but it can't be changed during a program run.
    You could replace your G00's with G1's and set the feedrates to whatever you want.
    Apr 2005
    3634
    Guess "Siemens 840D" spoiled me, being able to control G00 line by line!
    Yea thats what I was thinking, just add comments to make the rapids stand out in the program (easier to read).
    Jerry
    May 2005
    2502
    Help me out here: why do I want to change my rapids line by line?
    Just curious. It would seem that rapids should be, well, rapid. Not cutting, so why does it matter to tune them on this basis?
    Best,
    BW
    Apr 2005
    3634
    Quote Originally Posted by BobWarfield View Post
    Best,
    BW
    Maybe I should have said " axis " instead of " line by line ".
    What I was getting at, was I wouldn't want my " X-axis " & my " A-axis " to have the same rapid feedrate.
    I run a 5-axis grinder at work (Siemens 840D), I was just comparing to Mach3.
    I would like to have a 4-axis ( X,Y,Z, & A ) mill at home, just getting an idea what Mach3 offers.
    Each axis does have it's own rapid rate.
    May 2005
    2502
    To amplify on Gerry's point, each axis has individual motor tuning parameters that establish the maximum velocity (e.g. rapids rate, we need to get away from calling that the "feedrate") and acceleration curve.
    So assuming you want to set it once to optimize for a particular machine, Mach 3 can do that axis by axis.
    Best,
    BW
