587,776 active members*
2,466 visitors online*
    Feb 2015
    Indexing on Plasmacam 4x4?
    I've got a part that's 90in long, but only a 4x4 table on my plasma cutter. It seems like its possible to split the operation into two parts, but I haven't found any resources on how to do that.
    Has anyone here had any experience with this kind of thing? Is there a standardized way of doing it or should I just create two separate .dxfs, move it myself and hope for the best?
    Jan 2008
    2247
    Re: Indexing on Plasmacam 4x4?
    The video manual that comes with every Plasmacam has a section on indexing long parts, it is rather simple. If you don't have the video manual, then I suggest going to the plasma cam owners forum at PlasmaCAM Cutting Systems , click on Owners community, you will need your machine serial number to join. Great forum with lots of help from other Plasmacam owners.
    Jim Colt
    Quote Originally Posted by Jakebotd96 View Post
    Sep 2014
    112
    Hi Jakebot!
    True, plasmacam's video manual has really good step by step video instruction on everything having to do with plasmacam's machine and software.
    Plasmacam's machine control software makes indexing a really simple.
    Attachment 269484
    first go to the machine control tab in the settings menu. Then, under indexing and viewing (highlighted) select the table/viewing size (it can go all the way up to 4x40!!)
    Attachment 269480
    Click just once to make your lead in (to begin your cut path)... & I kid you not..... plasmacam's software will take care of the rest......it will even automatically create the cut path in separate sections for you. (I have never been able to make something like this go faster on any other system that I have used in the past).
    Attachment 269478
    Hit cut....and you are done!
    Attachment 269482
    Let me know if I can help.
    JAG
  1. PlasmaCAM 3d
    By AmesMFG in forum PlasmaCam
    Last Post: 03-29-2015, 04:15 AM
  2. plasmacam dhc
    By cmarshall72 in forum PlasmaCam
    Last Post: 06-10-2011, 10:45 PM
  3. Plasmacam help
    By fredjm in forum PlasmaCam
    Last Post: 06-05-2011, 05:42 AM
  4. Looking For used PlasmaCam
    By davismetal in forum PlasmaCam
    Last Post: 03-01-2011, 04:28 PM
