586,724 active members*
3,795 visitors online*
Results 1 to 6 of 6
    Mar 2009
    14
    Z Axis inaccuracy with Big-Tex Probing?
    I have recently installed the Big-Tex Probing screen v3.2 which seems to work absolutely fine.
    However, after much testing now, I am getting a consistent error in that, once I take the touch plate away and 'GotoZero' I am always left with a clearance of 0.015" above the workpiece?
    I have checked and re-checked everything I can think of which would affect the accuracy of the machine as follows.
    1. Z axis movement 100% accurate when measured using a DTI (within 0.0005 over a 1" travel).
    2. Plate thickness set at 0.07874" (2mm Brass Plate).
    3. Z axis movement is smoothly operating with no binding.
    4. All offsets set to zero prior to using the probe function.
    5. Have tried various 'Debounce' settings between 0 - 2000 with no improvement or difference.
    The Z axis has a 3" total movement (Marchant Dice manufactured) and has proved itself over time to be very reliable and accurate.
    I really am stumped as to where this inaccuracy is coming from as most people seem to get very good results using this screenset - it's just that I can't seem to get the accuracy that I'm looking for.
    Has anyone any idea why this is happening - or am I being too hopeful in looking for this degree of accuracy.
    35538
    Re: Z Axis inaccuracy with Big-Tex Probing?
    Debounce has no effect on probing.
    Did you measure the actual plate thickness?
    Are you using the parallel port, or a motion controller?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2009
    14
    Hi Ger21,
    Yes I did measure the plate - once by vernier and twice by micrometer - both results tallying...
    And yes, I am using a parallel port.
    35538
    Is the tool actually touching the plate each time? Sometimes noise can trigger the input slightly early.
    Gerry
    Mar 2009
    14
    Definitely touching - twice in fact, once at 10.0 IPM and the second time at 5.0 IPM...
    Mar 2009
    14
    OK everyone, have sorted the issue now and would like to say it has all been my fault completely:withstupi
    As I said, I did all the measurements correctly - before actually finishing off the actual touch-off plate, which I backed with a piece of clear plastic to avoid marring the polished Brass/aluminium/stainless steel plates I use for engraving. Guess who forgot to add the thickness of the plastic? Doh!
    Anyway, many thanks Ger21 for making me think harder - I knew it must be something stupid,it was ME!!!
    If we didn't make any mistakes, we would learn nothing of any real value....
  1. Rack and pinion inaccuracy
    By shreifali in forum Linear and Rotary Motion
    Last Post: 07-29-2012, 10:20 PM
  2. Probing B axis with VM-3
    By machine_easy2 in forum Haas Mills
    Last Post: 04-15-2012, 12:31 AM
  3. 5 axis probing. Can Mach3 do it?
    By neilw20 in forum Machines running Mach Software
    Last Post: 02-10-2012, 05:40 PM
  4. position inaccuracy at high feed rate
    By ethanbrush in forum Fadal
    Last Post: 08-07-2010, 07:05 PM
  5. fanuc 6M control dimensional inaccuracy
    By cheetah650 in forum Fanuc
    Last Post: 08-05-2010, 01:17 PM
