our vertical machining center(built in 1981) is consistantly off measure parts. We are machining bores by circular interpolation and diameters are smaller than commanded. i had to program 91.6 mm to get 80 mm holes. whats more, if a play with feedrate, diameter i get also changes. i am disabling cutter diameter compensation on the control by g40. measures on the z axis are accurate. what can i look at?
thank you
