586,923 active members*
2,698 visitors online*
    Output wire connection problem
    Hi, I am new on the forum,
    I do install usb controller on cnc with no problem , but I bought a USB 6 axis controller that the output will close but when it open the relay stay on,
    I have connect it like the diagram they have supply...
    so the problem if I start output 2 for spindle start it will never close...the relay will stay on, even if I have install diode or resistor...
    Any help will be nice, I have 2 usb board ( one 3 axis one 6 axis ) both have the same problem
    thanks Erik
    May 2005
    1397
    Re: Output wire connection problem
    So contact the people you purchased it from for support.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    I did, first thing....they didn't reply, It been one year....I think I will buy A new usb controller...
    May 2005
    1397
    My I recommend buying quality from a US vendor who stands behind their product instead of the cheap crap from China with no support?
    I try to find a US seller for a 6 axis USB mach3 controller and nothing came out...I am using other controller 4 axis they run perfect but didn't find any 6 axis maybe I didn't look at the wright place...If you have a good supplier let me know thanks
    Erik
    Fabinmotion
  1. Replies: 13
    Last Post: 05-04-2022, 07:03 PM
  2. Replies: 1
    Last Post: 04-30-2013, 10:52 PM
  3. 8 wire Stepper motor wiring connection
    By hornet in forum Stepper Motors / Drives
    Last Post: 01-25-2013, 07:52 AM
  4. 8 wire steppers connection
    By michel colonade in forum CNC Machine Related Electronics
    Last Post: 02-17-2012, 07:45 PM
  5. Connection layout of Fanuc Wire Cut machine
    By Namnp2007 in forum Fanuc
    Last Post: 08-14-2010, 01:19 AM
