586,700 active members*
2,744 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Very cheap programming SW... anyone have it?
    Feb 2008
    547
    Ran across this slumming through e-bay. I know NOTHING about it and have no need of it myself. I have a full four axis CAM. I suspect that it is a basic 2 1/2 axis SW, but they give almost no information or details about it. There's a nice simple simulation picture... but that's it. It might be...I repeat...might be...worth playing with for someone learning but I really have no clue...then again... maybe it's worthless too...
    CNC Machine Programming Software | eBay
    Can it import a .dxf and convert it to an engraved path?
    I use Gsimple and try to use as many standard pockets and bulges as I can but there comes a time where you just have to draw it in 2D and import the tool path to get the shape that you want.
    Re: Very cheap programming SW... anyone have it?
    The picture in that Ebay link is from the simulation in AlphaCAM V7 ( I use it daily at work).
    May 2005
    1662
    The software is conversational using NoteTab.
    The seller shows example gcode output running in simulation but does not describe the software as having a graphic component.
    If I'm right the ad is a bit misleading but nothing illegal going on.
    Sep 2012
    1195
    This appears to be his website:
    CNC Programming Software
    There are also videos if you google CNC Probuild.
    Jan 2007
    1795
    indeed looking as a macro collection for ms word..
    possible the guy made some macros under wordpad..
    I didn't used word for this,,, but used excel, to converting absolute to incremental...
  1. Xilog 3 Parametric Programming Offline Programming
    By julioykaly in forum Commercial CNC Wood Routers
    Last Post: 04-27-2013, 09:22 PM
  2. Replies: 1
    Last Post: 01-31-2011, 11:29 PM
  3. Cheap HF router bits, just plain cheap?
    By sonicwonder2000 in forum DIY CNC Router Table Machines
    Last Post: 09-04-2009, 03:18 AM
