587,913 active members*
3,677 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Brass for the first time on my Stepcraft
    Dec 2014
    4
    Hey all. New here, been lurking and learning for a while and have had fairly good results with my first week on CNC with some plastics and wood. I tried to do some brass today in an attempt to finish up a gift for my girlfriend for Christmas. No luck due to tool breakage. Would really like to be able to get it done in time!
    The pieces I am cutting are from 3mm brass. Mostly ground down to result in 1mm sheets with 2mm pegs sticking out. I broke my only 2mm end mill and two 1.1mm carbides. I believe I had the feedrate set too high at first on the 2mm, at 50mm/s. I went down to a tiny 4mm/s on the 1.1mm end mills but they still broke almost instantly. RPM was maxed at 20,000 and I was using pass depths and stepover of just 0.2mm. All bits broke on the very first stroke. Any suggestions?
    Cheers
    Dec 2014
    4
    Re: Brass for the first time on my Stepcraft
    P.S. Should this be in woodworking machines due to my CNC, or..?
    Jan 2015
    I have a woodworking mill that I've cut metal several times. The smallest bit I've used was 1/8 inch but my depth was still only about .2mm each pass. It worked fine for that, no breakage, but I did have problems with deeper cuts. I'm thinking a .2mm cut is too deep for a 1.1 mm bits. Oh, mine was air-cooled too. I understand you can cut deeper/faster with oil/mister cooled, but I don't have that option here yet.
    Jul 2011
    39
    Fadal VMC Fanuc Wiring Diagram - CNC Manual
    CNC Manual - CNC Machine Manuals PDF Download Read Online
    Mazak Manuals - CNC Manual
    All Manuals about CNC Mazak Manuals
    Read & download All CNC Manual without limits
    Your best companion in CNC #Machine shops
    CNC Manual - Read & Download CNC Machine Manuals without Limits on any device
    http://cncmanual.com/
    Aug 2003
    494
    Brass can be a real bugger to cut if you have a positive rake angle on your cutters. You need a zero rake angle to stop the cutter from digging into the metal. Are you using a spiral end mill? Try a straight sided milling cutter like the one below and if you can just hone a flat along the cutting edge to make it zero angle ( I would try it without doing that first though ). Try a wood router bit if you have to. You also need a fast spindle speed.
    Hope this helps a bit.
    Rich.Attachment 266474
    I am not completely useless.......I can always serve as a BAD example.
  1. Stepcraft cnc/3d-systems machines
    By cncadmin in forum Stepcraft
    Last Post: 12-14-2014, 02:56 AM
  2. Replies: 10
    Last Post: 01-16-2013, 06:52 AM
  3. Replies: 0
    Last Post: 04-24-2012, 01:46 PM
  4. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
