586,934 active members*
3,083 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > My Series 3 Motion Upgrade drive plugs melted today
    Mar 2008
    75
    Attachment 257802
    Has this happen to anyone else with the upgrade? I haven't run the mill in about 3 weeks and today I smelled wires cooking. I looked and one drive plug was melted and a second drive was hot. I bought the kit 11 months ago and it has worked mint. Any help would be great.
    Tom
    May 2013
    455
    Re: My Series 3 Motion Upgrade drive plugs melted today
    I would call Tormach support right away
    7063
    Looks to me like the screws were loose, and/or the wires were not fully inserted into the connectors before the screws were tightened. Un-plug the connectors - are the pins in the driver burnt? I'm guessing not, in which case you simply need to strip the wires back a little, and properly install a new connector.
    Ray L.
    Mar 2008
    75
    Tormach is the best there on it!
    Jul 2011
    400
    I think SCzEngrgGroup nailed it. When inserting wires into this type of connector I always make sure they are fully inserted and tight by tugging on the wire after I tighten the screw. Its quite possible for the screw to be tight and for the wire to have no tension on it at all. The pull test will always detect this.
    Sep 2012
    1543
  1. Series 3 upgrade
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 01-04-2014, 07:30 PM
  2. Anilam 1100 Memory Upgrade - IDE Solid State Drive or CF drive
    By Mike Mattera in forum Controller & Computer Solutions
    Last Post: 11-04-2013, 02:44 AM
  3. Very odd thing happened on my Series 3 770 today?!?
    By wwendorf in forum Tormach Personal CNC Mill
    Last Post: 03-11-2013, 07:11 PM
  4. TEKdrive Servo Drive Official Release Today!!
    By Kookaburra in forum News Announcements
    Last Post: 05-14-2006, 11:32 PM
