586,948 active members*
2,625 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal under cutting
Hybrid View
    Feb 2007
    171
    Fadal under cutting
    Has anyone heard of their Fadal undercutting when using a G2 or G3. Controller cards and processor has been changed out. The axes are on High Gain to make sure they hit their points, but it still undercuts by about .007"
    I have tried everything I can think of and have not solved the problem. I'm hoping someone else has heard of this with a solution.
    Brian D.
    Aug 2014
    22
    Re: Fadal under cutting
    Did you come up with a solution ?
    I have the same problem.
    break out the cylindrical square, and indicator, do basic geometry checks first, then come back with results for advice
  1. Error in cutting on y-axis, I think it's the servo. FADAL 4020 - 88HS
    By fadalmatt in forum Servo Motors / Drives
    Last Post: 12-27-2014, 06:29 AM
  2. Replies: 3
    Last Post: 09-21-2014, 01:04 AM
  3. cutting round bar into hex on a 4th axis Fadal 4020
    By Michael82 in forum Mastercam
    Last Post: 05-25-2009, 03:59 AM
  4. Replies: 23
    Last Post: 11-17-2008, 10:28 PM
  5. Replies: 2
    Last Post: 04-09-2007, 08:43 PM
