587,023 active members*
4,120 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree journeyman 325
Results 1 to 9 of 9
    Oct 2010
    28
    Tree journeyman 325
    I recently purchased a 325 . I found a brochure for the machine online and it says it has a 2 speed ranges (50-3500 rpm) (50-6000 rpm). Is this optional spindles per model or is there a way to switch to the second range.
    Feb 2009
    6028
    Re: Tree journeyman 325
    Optional. Most were 6k I saw. Same spindles, just different pulleys.
    Oct 2010
    28
    That's what I thought, I tried putting my spindle speed at 4000 RPM yesterday and it gave me an "improper spindle speed" error.
    Thanks Underthetire
    Feb 2007
    85
    Not to dig this back up, but I need to switch my 3500 spindle to 6k. I found the pulley that which I need, but from what I have seen, something needs to be switch/tweaked/jumpered/something to get get it to recognize the new top speed. Has anyone done this and lived to tell about it? Is there any other differences than that? Different bearings or what ever? My machine has the Yaskawa 8000rpm motor and a recently swapped out spindle drive so I am pretty sure it is up to the task.
    Feb 2009
    6028
    Call Bob At ZPS (262) 758-6129. Probably need a new prom.
    Oct 2006
    60
    So this gets archived:
    To make the control on a J325 / J425 go from 3500 rpm to 6000, add a jumper from 24vdc in machine to wire/terminal 238. Most machine the 24vdc can be sourced at the adjacent terminal
    Bob
    Feb 2009
    6028
    Quote Originally Posted by zpsbob View Post
    Bob
    See, Bob knows all.
    Mar 2006
    12
    I noticed your post about changing the speed of your tree journeyman 325 and you said you had the pully I have been looking for one if you happen to have the part number and/or know where I might be able to obtain one I would be greatly appreciative thanks Chuck
    Feb 2007
    85
    I got the pulley from American Metric. It was a 10 groove, but I only needed an 8 groove or somehting like that. It was a year ago so my memory is a bit off. Also, it used BSW threaded screws instead of SAE to join the taper lock bushing to the pulley. It was what they had on the shelf and it worked out just fine. I just replaced the spindle pulley with a 5.2” 8 groove pulley from Ametric, it uses the 2517 taper lock bushing with a 28mm shaft (I have the Yaskawa 5hp motor in mine). I think there is about a slight error in the RPM (on the faster side). So that when I am at 5400 RPM it is a bit faster. But the only time this could be an issue is when running tapping cycles. But I do all my tapping at 500RPM or less so its not an issue. Also, on my mill I had to replace the Spindle drive as the factory unit ate crap and died a couple years ago. With the new pulley, I get a spindle not up to speed fault when spinning up to 5500RPM (which is where I am usually cutting aluminum as I don't think going wide open is a good thing), but it only flashes then goes away and the mill keeps on going. I think that the spindle drive I put in isn't quite large enough to push the current through needed for start ups. But I don't really want to have to mess with or pay for swapping in another drive. You may have to monkey with the start/stop time settings on your drive, maybe. I don't know since I never ran my mill with the 6k set up on the factory drive. It died about a year before I did the swap. Also, you will probably have to call Ametric to order as their site is the suck right now. And, odds are, you will probably have to special order that pulley which usually means a couple months of waiting since this stuff gets made in china. I know another guy on here had a local shop just strait up make him a new pulley on their CNC lathe then had it balanced at an Automotive machine shop. That will probably cost you a lot more, unless you have a CNC turning center. He made it to fit the factory Taper Lock bushing. Unfortunately I had to destroy the bushing on my factory pulley since it was so stuck on there. Was a royal PITA to get off. As for the belt, I used this one: Continental ContiTech Poly-V V-Belt, 635L8, Ribbed, 8 Rib, 0.185" Width, 0.38" Height, 63.5" Nominal Outside Length: Industrial V Belts: Amazon.com: Industrial & Scientific.
    I hope this helps some. IF you have any more questions, feel free to msg me.
  1. help tree journeyman 325
    By cnc beginner in forum Tree
    Last Post: 03-05-2014, 07:13 AM
  2. Tree Journeyman 300
    By hjl4 in forum Tree
    Last Post: 08-21-2011, 06:18 AM
  3. Journeyman 325 tree
    By ramsey321 in forum Tree
    Last Post: 09-12-2010, 11:05 PM
  4. Tree Journeyman 310
    By Gyro in forum Tree
    Last Post: 07-20-2007, 12:40 AM
  5. Tree Journeyman 310 and VFD
    By Provectus in forum Tree
    Last Post: 01-27-2007, 04:13 AM
