586,945 active members*
2,680 visitors online*
Results 1 to 5 of 5
    Mar 2012
    10
    Help PLEASE. error 11 motor over load
    During tapping cycle (with or without G84.2) our mill is screwing off
    Error #11 motor over load comes up.. And/or C axis motor overload. The machine does mot have a C axis
    The spindle seems to loose where it is pulsing forward and back (shaking motion) when tapping
    Trying to job "Y" using the jog button ...... Once the button is released the table shakes back and forth very rapidly ( shaking motion ) after 10-15 seconds no alarms have come up E-stop gets hit to stop it
    "X" axis sounds HORRID when jogged
    Wondering where to start digging in ?
    machine : VMC 15 Fadal mill been in use since 1999... Never abused ... Cuts brass / plastics 80% of the time
    Thanks in advance all
    Oct 2005
    278
    Re: Help PLEASE. error 11 motor over load
    You should tell us what machine, age and controller.
    Nate.
    Ann Arbor Meechigan
    Mar 2012
    10
    Anyone know of a good Fadal repair in the GTA (greater Toronto area). Other than SMS... We had an issue with one of their guys. I'm sure we are on the "blocked list"
    Mar 2012
    10
    Narrowed it down to the Coupler that joins the x motor to the ball screw. Is there a procedure to mount the x motor up to ensure everything goes in square ?
    VMC 15 Fadal mill (been running since 1999)
    Round motor
    Bryan
    Dec 2006
    585
    Most of the time the motor is a "C" faced mount which the flange on the motor and the ball screw housing match. I have mounted the motor and slid the coupling back and forth between the motor shaft and the ball screw shaft. When the coupling slides evenly you know that the shafts are aligned. Then you can tighten the coupling.
    Mike cncmachineservices (dot) com
  1. V2xt Executive load failure error code 1
    By cr500250r in forum CNC Machine Related Electronics
    Last Post: 09-01-2014, 04:59 PM
  2. DC Gear motor and power off brake(on the load side not on motor)
    By glomagno in forum Mechanical Calculations/Engineering Design
    Last Post: 04-10-2014, 05:41 AM
  3. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  4. motor over load #12
    By Delw in forum Fadal
    Last Post: 07-29-2008, 07:14 PM
  5. Replies: 2
    Last Post: 06-08-2007, 05:42 AM
