586,690 active members*
3,076 visitors online*
Results 1 to 7 of 7
    Oct 2014
    Question Walter HMC 500
    I hope I'm in the right forum... I got a Walter HMC 500 and I have the next issue... My partner has replaced the CMOS battery of the MAIN CPU and the configuration of the BIOS has lost, we tried to start the MAIN CPU BIOS setup but we don't know how... Anyone can help us?
    Thanks in advance
    Sep 2009
    7
    Re: Walter HMC 500
    Hi Hugo, do you can start the MAIN CPU bios ?? How do you do ??
    Regards
    Sep 2015
    26
    Re: Walter HMC 500
    I know this is an old thread but I want to see if anyone has any information on a similar issue.... We are getting a CMOS RAM does not exist fault... I am assuming this is similar to a typical RAM card but I do not know which... I also need options to repair this or reflash what needs to be done... Any input will be greatly appreciated.
    Sep 2009
    7
    Re: Walter HMC 500
    Quote Originally Posted by Miller6386 View Post
    Hi Miller i can comment what we do when we have te problem:
    May be you need to take some pictures from BIOS Setup
    1st We discconect the cpu boards and clean the pins with an eraser and inset it again
    2nd change the date in the bios and y DOS we use a date in 1996 (we have a 2YK)
    Check Disk with scandisk and try
    I hope this will help you
    Sep 2015
    26
    Re: Walter HMC 500
    Quote Originally Posted by omarms View Post
    Can you elaborate on how to get into the bios.... looks like what I'm assuming my date is on the start up screen is reading 8:11:19159
    Sent from my SM-N950U using Tapatalk
    Sep 2009
    7
    Re: Walter HMC 500
    Hi; if you want to enter in BIOS only press the DEL key a cuple of times after turning on; and thats all; then find the date option; someting like this
    Attachment 377648
    Regards
    Sep 2015
    26
    Re: Walter HMC 500
    Hi; if you want to enter in BIOS only press the DEL key a cuple of times and thats all; then find the date option; someting like this
    Attachment 377648
    Regards
    Thank you very much... I actually found what I believe to be the card where the info is stored and the battery is dead. I am trying to locate a replacement board or a battery I can solder in and then re load missing information.
  1. Walter CNC Grinders
    By Durkee in forum Toolgrinding / Toolgrinding Machines
    Last Post: 06-08-2021, 06:13 PM
  2. Walter Grinder
    By Burnout2676 in forum Toolgrinding / Toolgrinding Machines
    Last Post: 08-13-2013, 01:07 PM
  3. How do you resharpen a tap using the Walter hmc 500?
    By hkpd in forum MetalWork Discussion
    Last Post: 05-29-2013, 02:54 PM
  4. WANTED USED WALTER HMC 400
    By hemara in forum Toolgrinding / Toolgrinding Machines
    Last Post: 12-21-2010, 03:39 PM
  5. walter GC8
    By bobcor in forum Toolgrinding / Toolgrinding Machines
    Last Post: 07-15-2005, 06:17 PM
