587,414 active members*
3,066 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Tool changer crazyness after a move...need help/ideas
Results 1 to 9 of 9
    Jan 2013
    11
    Im setting up may 97 VMC15 after moving it to a new shop space..... now my tool changer will replace tool to the tool wheel then lift up as it should then it turns the wheel3 and a half spaces then stops and shows an ATC failure message... any ideas on what this could be....thanks for any help
    Feb 2009
    6028
    Re: Tool changer crazyness after a move...need help/ideas
    Phase backwards?
    Jan 2013
    11
    every thing else on the machine is working fine ...spindle comes up to full speed and XYZ axis's are all working fine.... the tool changer was removed for this move but I don't think wiring has been changed?
    Feb 2009
    6028
    I'm sure the spindle and axis are not phase sensitive, the coolant pump would be. Just a thought.
    Dec 2004
    126
    all of the fadal pumps I have are single phase... never seen a three phase pump on a fadal...
    Jan 2013
    11
    Im 99.9% sure phases are OK I think its some kind of sensor on either the tool carousel or in some other point along the line..... anyone know any techs in the NYC area?
    Jan 2008
    45
    One of your sensors has a metal chip on it . The Proc sensor cant read its position so it faults. Clean out the Carousel with a blow gun and try again.
    Jun 2008
    51
    Something similar happened on the 4020 here. Turned out the (2) bolts holding the carousel to the movable arm had come loose. This resulted in wobble in the carousel that caused the limit switch to trip intermittently.
    The tool changer on a Fadal is controlled by 2 hall effect switches, these switches require a magnet to energize the switch. These are not inductive proximity switches that can be fooled by chips on the switch. From here I have no idea why the carousel is not positioning correctly, however ALL the Fadal manuals including maintenance manuals are available on fadalcnc.com
  1. Auto tool changer Armless type tool magazine.
    By maylin1105 in forum News Announcements
    Last Post: 02-16-2012, 03:27 AM
  2. Gadget ideas to move the TL-3 tailstock.
    By TXFred in forum Haas Lathes
    Last Post: 08-06-2011, 01:59 AM
  3. Automatic Tool Changer Ideas?
    By gbesch in forum CNC Tooling
    Last Post: 03-17-2010, 01:45 AM
  4. Need to move tool changer on HS-1
    By smoore64 in forum Haas Mills
    Last Post: 09-14-2009, 01:47 PM
