587,753 active members*
3,008 visitors online*
Results 1 to 12 of 12
    Oct 2014
    7
    workplan sparks for Co2 Laser MAchine
    GOod morning,
    I've 80W Co2 laser machine, my question it's easy.
    I've the combo steel work plan and in my cut working makes the sparks that leave the points in the cut line on the material, this is no very clean.
    Have you some suggestion about the work plan or some other material that I can put on the work plan?
    :idea:
    Re: workplan sparks for Co2 Laser MAchine
    pls use gasoline to clean it
    tina from g.weike laser
    EMAIL: [email protected] SKYPE: lysunshine521
    Oct 2014
    7
    Gasoline? Thank for the suggestion, I'll try it.
    But the spark depends when my laser spot hit the steel line on the work plane,
    why to clean by gasoline solution?
    Quote Originally Posted by laserItalex View Post
    GOod morning,
    :idea:
    do you mean points in the cut line like below picture?
    www.thunderlaser.com
    Oct 2014
    7
    yes, it's this!
    have you the solution?
    do not put the material on the steel work table directly,
    try to put your material on stilts,
    (leave enough space between the table and your material bottom)
    good luck.
    Oct 2014
    7
    yes I know this solution, good for big and easy cutting,
    but when I cut more and little pieces or thinnest material isn't easy,
    because or fall down or bend some parts before the cutting it's over.
    any way thank you.
    Jan 2008
    940
    I use egg rate light diffusers to keep this from happening
    Oct 2014
    7
    Please fixtureman1 , could you explain me what is the egg rate light diffusers, have you some picture or link please?
    ok, maybe I've understand what is, but which material do you use ?
    Oct 2014
    7
    yes maybe it's good, but I can't find the link where I can buy this?
    Jan 2008
    940
    Sorry it is egg crate diffuser should have proof read this better. It is plastic and will not reflect the beam
  1. Plasma Sparks Protection on Mill?
    By Cartierusm in forum Waterjet General Topics
    Last Post: 10-24-2010, 07:58 PM
  2. Sparks HobbyCNC Pro Cant Be Good
    By droddis in forum Hobbycnc (Products)
    Last Post: 10-28-2009, 12:18 AM
  3. Do any sparks at all mean too much rpm?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-17-2009, 08:23 PM
  4. Lathe motor sparks on startup
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 04-06-2006, 06:14 PM
  5. Smoke and sparks?
    By Marc Soren in forum CNC Machine Related Electronics
    Last Post: 10-14-2003, 01:46 AM
