587,175 active members*
3,001 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 4 with Heidenhain TNC150 programming from PC
    Oct 2014
    Hello All,
    I am a total newbie to all this stuff, but I was wondering if any of you had any luck with programming the Bridgeport Interact 4 from a PC? It has a Heidenhain TNC150 controller. Now I know this is pretty ancient (or at least it is to me), but it does have what looks like some kind of serial or parallel port on the side. According to the manual this is for a tape reader or something, but programming it by hand is a right pain, and if you can send G-code or something to it from some software on my laptop, that would be much (much) easier.
    Anyway, I hope this isn't a duplicate of a post that is already on here, and if any of you have an idea on how I could get my laptop talking to the mill, that would be greatly appreciated.
    Many Thanks
    Rob
    Jan 2011
    31
    Re: Bridgeport Interact 4 with Heidenhain TNC150 programming from PC
    try down loading tnc remo from heidenhain , you will have to set machine and remo up to talk to each other but this is a good tool for transferring programs
    Jul 2014
    22
    Hi, if its the same as ours then thats the port that plugs into the computer, you will need to buy the cable to suit, the port you need is hard to find on the new computers but you can buy a usb connector, and we have used software called cncedit to Send the programs to the machine but there is various pieces of software that can be used.
    Hope this helps
  1. Bridgeport interact 4 series 2, TNC150, Connect power cables, how?
    By MattiasR in forum Machinery Manuals / Brochures
    Last Post: 08-08-2013, 01:03 PM
  2. Bridgeport Interact 1 MK 2 Heidenhain 151
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2012, 05:07 AM
  3. Bridgeport Interact 412/Heidenhain TNC 151 HELP?
    By larrynsr in forum Bridgeport / Hardinge Mills
    Last Post: 03-17-2012, 08:21 PM
  4. Bridgeport Interact 1 MK 2 Heidenhain 151
    Last Post: 11-30-2011, 11:35 PM
  5. Heidenhain, Bridgeport TNC150 problems!
    By mossy in forum DNC Problems and Solutions
    Last Post: 10-01-2008, 07:08 PM
