Our Okuma VTL has the above controller and I believe it has macro-b because it executes #101=1 without an alarm. The problem is I cannot find the variables page on the control. It's not where it should be. I don't see a parameter that controls turning this page on and off. I want to see the values in system variables (offset variables actually) by putting them in the common variables.
The reason for this is because I cannot input offset values using the G10 command in this control, I get the "Improper G code alarm" when I MDI G10. So my only other option is to use macro to pass the values to the correct offset.
So long story short, does anybody have any idea how I can see the values in the variable without being able to navigate to the page in the control?
Thanks.
