585,762 active members*
4,177 visitors online*
Thread: 18i-TB macro
Results 1 to 2 of 2
    Feb 2006
    24
    18i-TB macro
    Our Okuma VTL has the above controller and I believe it has macro-b because it executes #101=1 without an alarm. The problem is I cannot find the variables page on the control. It's not where it should be. I don't see a parameter that controls turning this page on and off. I want to see the values in system variables (offset variables actually) by putting them in the common variables.
    The reason for this is because I cannot input offset values using the G10 command in this control, I get the "Improper G code alarm" when I MDI G10. So my only other option is to use macro to pass the values to the correct offset.
    So long story short, does anybody have any idea how I can see the values in the variable without being able to navigate to the page in the control?
    Thanks.
    Sep 2011
    78
    Re: 18i-TB macro
    parameter 9000 bit 1 (NDP). Needs to be set to 1
  1. Accessing Macro Variable from another macro
    By ex-egll in forum Mach Wizards, Macros, & Addons
    Last Post: 02-01-2014, 06:52 AM
  2. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  3. Replies: 3
    Last Post: 02-13-2012, 07:20 PM
  4. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  5. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
