587,935 active members*
4,179 visitors online*
    Apr 2014
    36
    Looking for a faster cut
    My material is a Beech 1.25" thick seat. I am currently taking .325 passes with a 7/16 2 Flute straight cutter.at approx 300ipm with a spindle speed of 14k RPM. This beech comes out extremely smooth in most places and just a tad rough against the grain. I have about 8,000 to run over the next few months and am looking for a better feed rate. I have tried up and down cuts but I tend to get a little blow out on edges with spiral bits. If you have any ideas on a better setup, please feel free to comment. I am looking for any ideas you might have. I have tried cleanup passes but the seats will be sanded on the sides regardless so I am just looking for a faster rate to cut these without blowout. I cannot get the video to post but I doubt its really needed.
    Jun 2013
    1041
    Re: Looking for a faster cut
    Use a compression spiral bit and make sure the first cut is deeper then the upcut section of the tool.
    Ben
  1. new to cnc and getting confused faster and faster
    By keastab in forum Community Club House
    Last Post: 12-25-2011, 02:07 AM
  2. Will mach 3 let Z go down faster than up?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-29-2009, 03:14 PM
  3. need a faster hole
    By Stevo911 in forum Material Machining Solutions
    Last Post: 02-27-2009, 01:13 PM
  4. Want to go faster
    By doesitfloat in forum Gecko Drives
    Last Post: 11-14-2007, 07:21 PM
  5. Faster TM1?
    By drewmeister in forum Haas Mills
    Last Post: 02-21-2007, 05:27 PM
