586,675 active members*
2,904 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > SolidCam + Mach3 50+ Parts - pattern (Offset) etc...
Results 1 to 12 of 12
    Nov 2010
    13
    Question SolidCam + Mach3 50+ Parts - pattern (Offset) etc...
    Hi, first post here, need help for SolidCam part pattern, if it's possible of course...
    So the thing is I have plastic sheet (1200x600mm), from that sheet I need to get 50 smaller pieces (50 exact the same toolpaths),
    At first I thought that I would use Mach3 offsets and use sub program of same toolpath, but I cannot get it working - its so simple but so complicated at the same time. First - Mach3 decides to clear second (G55) offset value and much more problems.
    So what would be the best solution for this specific job? I thought maybe SolidCam has "pattern" or pre processor Offsets?
    Any ideas? Thanks.
    Nov 2010
    13
    Re: SolidCam + Mach3 50+ Parts - pattern (Offset) etc...
    Just had an idea:
    What if I useSub-Program, reset axis on each part and at program end return to first part start position - First mill one part at X0Y0, then move axis to second part zero position, zero X and Y axis and use sub-program again at X0 Y123, then X123 Y0 etc...
    Any ideas?
    Oct 2013
    64
    Try to use g91.
    Oct 2013
    153
    Transform command in solidcam will do that for you . Just create the tool path for one piece and use the transform option as you want either circular pattern or rectangular
    Nov 2010
    13
    Before I started to work, at this moment I have one piece drawing with complete toolpaths, can I transform it without redrawing complete sheet with 50 peaces? Or SCAM must have transform part? Maybe extending Stock is enough?
    Oct 2013
    153
    No need to have a transform part . For stock if you want to see the simulation you need to extend the stock size . Select all your operations right mouse click then select transform from the drop down menu . Use translate\matrix\ then just fill up the Columns on the box
    Nov 2010
    13
    Everything is clear until "fill up the columns on the box" If I select all operations, in list appears "Multiple operations..." If only one - that operation name. Right click - I can add matrix etc but if i enter matrix count and click OK it doesnt do enything, click OK again to apply transform, nothing happens. ?
    Nov 2010
    13
    Attachment 250072
    This is what I get
    Oct 2013
    153
    you should see like thisClick image for larger version.
ID:	250088Click image for larger version.
    Nov 2010
    13
    Pretty dumb mistake Didn't set X - Y steps. Thank you! Works like a charm now. Will see how Mach3 eats that g-code
    Oct 2013
    64
    You can do it with transform command.
    Nov 2010
    13
    So here we go again,
    I have problem that I need to drill and pocket each part individually, using transform I get every single operation on all 50 parts, (drills holes in each part, just then makes pockets etc..) What I need is to drill, pocket one part, then drill pocket another.
    Any suggestions?
  1. Newbie - Solidcam and Mach3
    By beluga282 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-19-2016, 12:56 PM
  2. Replies: 3
    Last Post: 07-13-2014, 11:19 PM
  3. Multiple identical parts in a pattern
    By Molsongr in forum G-Code Programing
    Last Post: 06-17-2014, 05:22 AM
  4. Mach3 5axis Solidcam
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-20-2014, 04:49 PM
