586,822 active members*
3,478 visitors online*
Results 1 to 11 of 11
    Jul 2013
    4
    plasma cam in the works .
    Is there anyone with a plasma cam in northeast Pa . we are looking to purchase a plasma cam 5x10 for our shop . I would like to see one in action before we buy , any help would be appreciated .
    Jan 2008
    2247
    Re: plasma cam in the works .
    Plasmacam is a good choice, I have had their machines for over 15 years, easy to learn, easy to use. I suggest getting the advanced Design Edge software and advanced height control options, will be worth every penny over time. You may want to post this on the PlasmaSpider.com ? Index page as I think there may be many more Plasmacam users on that forum. You are welcome to come to NH and take a look at mine.
    Jim Colt
    Sep 2014
    112
    Jim,
    You're one stand up guy! Thanks for helping all of us guys out when considering a new machine.
    You can blame plasma cam's DesignEDGE Software for this one:
    Attachment 250034
    Sep 2014
    112
    Here is another sweet plasmacam cut out using DesignEDGE:
    Attachment 250036 Attachment 250040
    Jul 2013
    4
    thanks for the info . we received the machine and now in the process of making a down draft table to make the shop as smoke free as possible.
    Sep 2014
    112
    a Downdraft is definetely the the way to go,
    These might be helpful for a 4x4 plasmacam (allows you to get away with a much smaller ventilation fan, because the enclosure area is reduced):
    Attachment 255988
Name:	DOWN DRAFT VENT 3.jpg
    Sep 2014
    112
    I found a instructional video for a downdraft for a PlasmaCAM:
    JAG
    May 2015
    31
    Do you have the dxf for this table?
    Jul 2013
    4
    Quote Originally Posted by MetalDawg View Post
    sorry no we did some thing totally different . we built a water table and ducting on the sides for a side draft vacuum .
    Sep 2014
    112
    Check out Plasmacam's owners community on their web site. There is definitely a few plasmacam owners that have build these for their systems. I'd say that would be best place to see if you can track down a dxf for it. If worse comes to worst, something like this would be extremely easy to lay out and cut using your designedge software.
    Let us know if you come across something.
    Good Luck Brother!
    JAG
    There is one in Southeastern PA and Central, PA, and Western, PA
  1. Plasma THC config that actualy works.
    By tommylight in forum LinuxCNC (formerly EMC2)
    Last Post: 07-28-2015, 12:46 AM
  2. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  3. Only Y works correct X don't work Z works one direction only
    By jdgbadenhorst in forum Hobbycnc (Products)
    Last Post: 06-10-2012, 09:54 PM
  4. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
  5. my cheap cnc plasma cutter (650.00) works great
    By vdoug in forum Uncategorised MetalWorking Machines
    Last Post: 01-05-2011, 04:22 PM
