587,468 active members*
3,239 visitors online*
IndustryArena Forum > Material Technology > Plastic injection > Clarke 911 thermoforming centre
    Feb 2010
    3447
    Hello everyone, came across a pretty cool item that I've wanted access to for a long time but could never afford the full size machine. Here we have a prototype educational machine that does 6 processes in one machine. Apparently it's pretty expensive, I was told $10,000 and found the same unit online in euros in accordance with his claim. I picked it up with a ton of plastic and all the attachments and books for $500. Anyways, it has a small 1 ounce plastic injection feature, pid controlled oven, vacuum mold, blow mold, plastic welder, and plastic coating apparatus, along with an extrusion maker. Clearly this isn't a high production machine, but it's made VERY well and better yet runs on 110V @ 20amps. The vacuum pump/ compressor are internal I assume oil less . Should make a fine match for my 3d printer when/if I need to make a mold for multiple copies. Attachment 249698
    Feb 2010
    3447
    Re: Clarke 911 thermoforming centre
    Well overlooked that it was 220V and not 110 when buying plugs oops. Found a place for a couple cheap molds that im going to test out from these guys.
    Plastic Injection Molding, LNS Technologies Plastic Injection Molding Machines and Supplies Home
    Jul 2007
    1602
    Congrats on a great purchase! That is the cat's meow. You will learn so much from that machine.
    Now I know what to look for...
    bob
    Feb 2010
    3447
    Thanks bob. Ya it looks like a great machine, especially for that initial exposure to plastics in general.
    Oct 2016
    5
    Hi there, I'm considering buying the same machine - can you tell me if it turned out to be a good purchase or a regret?
    I'm initially interested in vacuum forming, but of course, there's always room for doing other things.
    OR if you know of another machine that you could suggest, I'm open to that also.
    Thanks in advance!
    Feb 2010
    3447
    Ya, good machine if you can get it cheap. They are expensive new.
    Sent from my SM-N910V using Tapatalk
  1. Clarke Mill Drill
    By redpiperbob in forum For Sale Only
    Last Post: 07-26-2014, 06:28 AM
  2. SIEG = Clarke?
    By nophead00 in forum Mini Lathe
    Last Post: 10-18-2008, 12:49 AM
  3. Anyone have a Clarke engineers workbench?
    By daedalus in forum Benchtop Machines
    Last Post: 10-27-2007, 11:11 PM
  4. Clarke CMD10
    By plexer in forum Benchtop Machines
    Last Post: 09-09-2006, 09:01 PM
  5. Clarke MIG 180 AMP
    By georgebarr in forum Welding Brazing Soldering Sealing
    Last Post: 05-03-2006, 08:58 PM
