Hello,
I purchased a Donek Drag Knife and I need to set in the NCstudio post processor that the spindle doesnt start.
Here is the vectric aspire PP configuration file.
Does anyone know where to look for?
+ NC Studio Vectric output configuration file
+ History
+ Who When What
+ Mark 07/09/2010 Written
POST_NAME = "NC Studio ATC Arcs (mm)(*.nc)"
FILE_EXTENSION = "nc"
UNITS = "MM"
+ Line terminating characters
LINE_ENDING = "[13][10]"
+ Block numbering
LINE_NUMBER_START = 0
LINE_NUMBER_INCREMENT = 10
LINE_NUMBER_MAXIMUM = 999999
+ Formating for variables
VAR LINE_NUMBER = [N|A|N|1.0]
VAR SPINDLE_SPEED = [S|A|S|1.0]
VAR FEED_RATE = [F|C|F|1.1]
VAR X_POSITION = [X|C|X|1.3]
VAR Y_POSITION = [Y|C|Y|1.3]
VAR Z_POSITION = [Z|C|Z|1.3]
VAR ARC_CENTRE_I_INC_POSITION = [I|A|I|1.3]
VAR ARC_CENTRE_J_INC_POSITION = [J|A|J|1.3]
VAR X_HOME_POSITION = [XH|A|X|1.3]
VAR Y_HOME_POSITION = [YH|A|Y|1.3]
VAR Z_HOME_POSITION = [ZH|A|Z|1.3]
VAR SAFE_Z_HEIGHT = [SAFEZ|A|Z|1.3]
+ Block definitions for toolpath output
+ Commands output at the start of the file
begin HEADER
"o0001"
"( [TP_FILENAME] )"
"[N] G91 G28 [XH] [YH] [ZH]"
"[N] G00 G21 G17 G90"
"[N] G00 G40 G49 G80"
"[N] G71"
"[N] T[T] M06"
"[N] G00 G43[ZH]H[T] M8"
"[N] [S] M03"
"[N] [XH] [YH] [F]"
+ Commands output for rapid moves
begin RAPID_MOVE
"[N] G00 [X] [Y] [Z]"
+ Commands output for the first feed rate move
begin FIRST_FEED_MOVE
"[N] G01 [X] [Y] [Z] [F]"
+ Commands output for feed rate moves
begin FEED_MOVE
"[N] G01 [X] [Y] [Z]"
+ Commands output for the first clockwise arc move
begin FIRST_CW_ARC_MOVE
"[N] G02 [X] [Y] [I] [J] [F]"
+ Commands output for clockwise arc move
begin CW_ARC_MOVE
"[N] G02 [X] [Y] [I] [J]"
+ Commands output for the first counterclockwise arc move
begin FIRST_CCW_ARC_MOVE
"[N] G03 [X] [Y] [I] [J] [F]"
+ Commands output for counterclockwise arc move
begin CCW_ARC_MOVE
"[N] G03 [X] [Y] [I] [J]"
+ Commands output at toolchange
begin TOOLCHANGE
"[N] T[T] M6"
"[N] G43H[T]"
"[N] [S] M03"
+ Commands output for a new segment - toolpath
+ with same toolnumber but maybe different feedrates
begin NEW_SEGMENT
"[N] G00 [SAFEZ]"
"[N] [S] M03"
+ Commands output at the end of the file
begin FOOTER
"[N] G00 [ZH]"
"[N] M09"
"[N] G00 [XH] [YH]"
"[N] M17"
"[N] M30"
