587,036 active members*
2,816 visitors online*
Results 1 to 9 of 9
    73 beetle keeps blowing signal fuse
    At the collision center I work at we just repainted a mint condition 73 Super beetle with only 53K orig miles. When I say this car is mint, its truly MINT! Original owner and completely unmolested since new. Full service history since 73'. Original everything in perfect condition. Its literally a little old mans car. Its his pride and joy.
    Anyway, it keeps blowing fuse number 12 as soon as you turn on the signals. I'm thinking its a ground on either the front or rear signal lamps. Also when turning on the hazards it pops that fuse too.
    Any ideas?
    Thanks.
    MRO Supply
    Apr 2006
    3206
    Re: 73 beetle keeps blowing signal fuse
    Keeps blowing a fuse?
    IT ISN'T MINT.
    GOT IT???
    24223
    Service schematic would confirm it!!
    Al.
    Feb 2009
    6028
    Too bad its a super beet!e. Could be a ground, that would be typical German car issues. I've pulled new harnesses in a few vw/Porsche cars. Sometimes that's much easier than pinning everything out and dealing with 40 year old wiring.
    Jun 2009
    135
    Does both the left and right blow the fuse? Also are there separate brake lights in the rear or do the signals and brake share the same bulbs like most American cars of that era.
    If its a shared bulb and the brake lights do not blow the fuse the rear wiring is probably OK. If both left and right signals blow the fuse, the problem is probably in the steering column. If only one side blows the fuse check the wiring for that side.
    Nov 2014
    13
    Jan 2011
    It's definitely a short to ground on the supply side. Run some new wires. Old insulation gets brittle and flakes off. You will only have problem after problem repairing the old wire. Having a new set of wires will keep it in that 'like new' condition rather than having a wad of electrical tape somewhere.
    Mar 2016
    Try checking the ground in the steering column...
    I've rewired my '70 beetle, all of it.... What a learning curve that was....
    Sep 2006
    6463
    My daughter has a '67 Beetle.....Hitler's revenge.
    Ian.
  1. 3T Blowing VCU fuse
    By amercc in forum Fanuc
    Last Post: 10-19-2013, 06:21 PM
  2. 24v fuse blowing
    By CVMW in forum Fanuc
    Last Post: 04-23-2011, 07:36 PM
  3. blowing ifc dps fuse
    By robthomas in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2007, 01:20 AM
  4. Fuse Blowing! Please Help
    By audioandy1762 in forum Gecko Drives
    Last Post: 01-22-2007, 10:52 PM
  5. Fuse blowing at start-up
    By emergent in forum Daewoo/Doosan
    Last Post: 03-22-2006, 07:42 PM
