587,507 active members*
2,624 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Fuse Blowing! Please Help
Results 1 to 7 of 7
    Unhappy Fuse Blowing! Please Help
    Hi All
    I have just about finished my power supply and I am wanting to prove it before I go any further.
    My system is using the Gecko 210, I have wired everything up as per the instructions checked and double checked.
    Stepper motors are Nema 34 rated at 2.5volt @ 4.6 amp per phase, 8 wire, connected Bi-Polar parallel. The colour coding is as follows:-
    Red * Winding 1
    Red/White
    Yellow Winding 2
    Yellow/White*
    Orange* Winding 3
    Orange/White
    Black Winding 4
    Black/White*
    The above is connected
    Red and Yellow/White Phase A Gecko
    Yellow and Red/White Phase B Gecko
    Black and Orange/White Phase C Gecko
    Orange and Black/White Phase D Gecko
    The * denotes start of each coil, all of the stepper info was given to me by the motor supplier.
    I have limited the Gecko’s to 2amp with a 18k resistor just for the trial, when I power up the supply, the 5 amp fuse which is protecting the Gecko’s blows, but if I disconnect the stepper, the fuse holds and the Gecko power light is on. The supply voltage is about 48volts just below the 20 times the motor rating as per the recommendation from Gecko.
    The only thing I am not sure about is the way in which I have wired the windings to the Gecko so if one of the more knowledgeable people could help I would be most grateful.
    Andy
    Oct 2004
    742
    Andy,
    You have your windings wired 180 degrees out of phase. I would also recommend that you wire them in Series instead of Parallel, due to current consumpion and heat generation within the steppers.
    Red * Winding 1
    Red/White
    Yellow Winding 2
    Yellow/White*
    Orange* Winding 3
    Orange/White
    Black Winding 4
    Black/White*
    The above should be connected as follows for Parallel:
    Red and Yellow------------------------- Phase A Gecko
    Red/White and Yellow/White-------------Phase B Gecko
    Orange and Black----------------------- Phase C Gecko
    Orange/White and Black/White---------- Phase D Gecko
    Use Below For Series Wiring:
    Red----------------------------------- Phase A
    Red/White and Yellow (Connected and insulated)
    Yellow/White-------------------------- Phase B
    Orange-------------------------------- Phase C
    Orange/White and Black (Connected and insulated)
    Black/White--------------------------- Phase D
    Hope this helps.
    Jerry
    Hi Jerry
    Thanks for the reply.
    I connected the wires as per the stepper motor supplier stated I think!
    Quote
    For parallel connection the start of the coils should be together
    For series connection the start of the coil should be connected to the previous coil.
    Just glad I fitted the fuse hope I hav'nt damaged the Gecko. I will try your wiring tomorrow and post my results.
    Jerry will I loose torque if connected in series?
    I built my power supply to supply the extra current for parallel.
    Thanks Jerry for your help yet again its a steep learning curve but enjoying every minute.
    Regards
    Andy
    Oct 2004
    742
    Andy,
    I wrote a long reply to your post, but the site messed up and lost it. I got a site not found error when submitting the entry.
    Why don't you pick one method and wire it that way? If it does not meet your approval, then change the stepper wiring.
    Let us know the results. I am sure others would also be interested in your results using a 48 VDC power supply.
    Jerry
    Talking Thanks
    Hi Jerry
    Well you have done it again put a big smile on my face :rainfro:
    Wired it as per your instructions for the parallel connection, hey presto the fuse held connected the pc to the breakout board, loaded the road runner file into Mach3 and away she went, played around with the speed settings no problem with speed and seems to be loads of torque I could not stop the shaft from turning with the Gecko limited to 2 amps.
    I can now get the other motors wired up and tried, still along way off from a finished mill but with your help one BIG step closer.
    Thanks again Jerry
    Regards
    Andy
    Oct 2004
    742
    Keep an eye on the stepper motor temperature.
    The major problem I have with my 48 volt system running in series is heat from the stepper motors. After 3.5 hours of operation they begin to start missing steps because of the temperature. If I do not shut the system down, the motors will soon stall out from heat exhaustion. Excessive heat will de-magnetize the motors and ruin them.
    Parallel Wiring -- (If the current is not limited as you are doing) it will cause even more heating. About 3X faster, so just watch the temp on the motors and drives.
    Glad you are up and running.
    Jerry
    Cheers Jerry for making the point, once all three motors are connected I will do some tests with various current ratings and post the out come on the zone.
    This has now spurred me on to get my mill finished and up and running (not sure what I will do with it when it is running, but it should be fun building it)
    Regards
    Andy
  1. A Little Help Before I Run the Risk Of Blowing This Up
    By silver in forum CNC Machine Related Electronics
    Last Post: 12-17-2006, 05:34 AM
  2. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  3. BP series 1 x axis fuse blowing
    By keebler303 in forum Bridgeport / Hardinge Mills
    Last Post: 07-08-2006, 08:23 PM
  4. Fuse blowing at start-up
    By emergent in forum Daewoo/Doosan
    Last Post: 03-22-2006, 07:42 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
