587,021 active members*
4,729 visitors online*
Results 1 to 7 of 7
    Aug 2011
    9
    Inverted parts
    Hey guys, I've got a Torchmate 4x4 at work i'm fairly new to. All my parts look excellent when designed but when they cut, they are inverted. All the dross ends up on the side I need to have a quality cut on. Anyone else experience this or know what I might have set up wrong? Sorry if this has been covered already but I couldn't find anything on it. Thanks!
    Aug 2014
    10
    Re: Inverted parts
    What do you mean "inverted"? Is it cutting out the parts mirrored from what the software shows?
    Did you draw them with Torchmate CAD?
    Are you using the correct tool path? (ie. male for shapes & female for holes)
    Aug 2014
    7
    Re: Inverted parts
    Sounds similar to a problem I am having on my CNC build. I am running an engraved sign for testing and it suddenly is carving a mirror image of the design. I have Mach 3 sw and have had issues with the y and z axis stepper motors stalling. While troubleshooting that problem, I had made changes to the Mach 3 configuration motor tuning settings. I finally found my stalling problem was with some bad solder connections on my driver controller pcb. However even though it was carving correctly originally it is now reversed as amirror image. Anyone know if there is a setting in the Mach 3 sw that I may have changed inadvertently?
    Aug 2011
    9
    Re: Inverted parts
    I am running a Torchmate at work, it doesn't matter if i design with Torchmate or an external program its always mirrored, The only way i know to fix it so far is to design the part and then flip in before creating a cut path. Outside or inside cut path won't matter because that is based on with side of the part i am cutting ( inside or out). Now as for MAch3 i have that program i am running at home on my custom table and i like that a lot better, however a friend of mine is running Mach also and his is inverted on that machine, we haven't been able to figure his out either but i'm guessing there is a relation between Mach3 and Tochmate with the inverted images. Just need to find someone who has figured it out. Until then I'll keep working on it and if i figure it out ill be sure to let you guys know, thanks for the responses.
    Aug 2014
    7
    Re: Inverted parts
    Well I kind of got my problem resolved. I did some poking around in Mach 3 and under config/homing limits there is a column for each axis marked reverse. I unchecked the offending axis and then tested again . All looks good now. This is just a workaround until I finish my cnc build. At least it lets me test it. I have a backup hard drive with the Mach 3 software on it before I messed with it. When I get a chance I'm gonna swap hard drives and see if the problem goes away. If so It's the Mach 3 sw and something I did to it. Will post the results.
    Re: Inverted parts
    Quote Originally Posted by usweldpro View Post
    I am running a Torchmate at work, it doesn't matter if i design with Torchmate or an external program its always mirrored.
    I think I have a solution to this for the Torchmate. I realize this was a while back and things may be already taken care of...
    I seem to remember having this issue and I think I fixed it by changing the X axis motor direction... (Configuration/System/Motor Signals)
    Attachment 263536
    I would test this to know for sure that changing the motor signals would fix it, but the main reason I'm surfing around here today is because my table isn't working... So I can't test my theory...
    Aug 2011
    9
    Post Re: Inverted parts
    Quote Originally Posted by Jeonlyep View Post
    Attachment 263536
    Wow, I'm poking around on here for a different problem we have now, and seen this. Never figured it out so i went and tried it and it fixed the inverted issue. Thanks for the help! Much appreciated
  1. Inverted Curves in v24
    By Brain Dawgs in forum BobCad-Cam
    Last Post: 07-06-2012, 11:29 PM
  2. inverted y axis
    By Jack000 in forum Coding
    Last Post: 04-30-2010, 06:36 PM
  3. The (+)X and (-)X are inverted or switched
    By TAProwler in forum Torchmate
    Last Post: 01-18-2009, 01:22 AM
  4. 100-foot Inverted Tripod
    By jimbobbus3 in forum LinuxCNC (formerly EMC2)
    Last Post: 11-30-2007, 11:45 PM
  5. Mach2 inverted engraving
    By engraver in forum Mach Software (ArtSoft software)
    Last Post: 09-07-2003, 03:44 AM
