586,773 active members*
9,260 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > gecko g540 nema 23 425oz 2.8 amp need resistor
    Jul 2014
    4
    hi i am new here have buy gecko g540 and 3 nema 23 425 oz 2.8 amp 4 wire .
    my question is if i need a resistor on my motor if yes i put in wich wire and how omh please
    sorry for my english
    Jan 2010
    44
    Re: gecko g540 nema 23 425oz 2.8 amp need resistor
    I'm sorry that nobody ever answered your question.
    Yes you need a resistor or you can burn up your motor(s).
    The resistor goes across pins 1 & 5 - those are the 2 on the ends of the long side of a DB9 connector. The long side has 5 pins, the short side has 4 pins.
    The resistor value is driven by the amperage of your motor. In this case, you will need a 2.8k ohm resistor (1/4 watt is fine).
    Finally, the resistor is to be place on the connector that plugs into the Gecko G540.
    Hope this helps,
    P.S. Your English is fine - no problem understanding your question.
  1. Replies: 0
    Last Post: 12-17-2013, 01:14 AM
  2. Best PLace to Buy Gecko G540 w/ 3 Nema 23 motors?
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 11-23-2012, 08:34 PM
