586,704 active members*
2,495 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > MORI SL-3H X AXIS ENCODER RE-ALIGNMENT
Results 1 to 10 of 10
    Apr 2008
    11
    Hi all...
    Can somebody help with a procedure to re-align x axis encoder?.....it was removed for repair but now I need to realign,
    Your help would be much appreciated,
    Thanks in advance
    Oscar.
    24223
    Re: MORI SL-3H X AXIS ENCODER RE-ALIGNMENT
    If this is a normal incremental encoder on a DC motor, then there is no aligning usually, if the zero reference has to be in a certain position, as in tool changing etc, then it is normally done with a grid shift parameter to move zero where you want it, within one revolution of the encoder.
    What control is on it? 6T?
    Al.
    Apr 2008
    11
    Thanks for your response....the control is a Yasnac LX1...I wasn't sure if I had to re-align since we have several Fanucs and those you have to get into the parameters like you said
    24223
    Unless you have a reason for wanting it to zero exact position as before, it should not matter, it is within 1 rev of the encoder, you may have to adjust some programs however, unless the Yasnac has grid shift the same as Fanuc.
    Al.
    Apr 2008
    11
    We're within a turn...we'll just re-set our tool positions, it's no big deal...I will keep you posted when I get it going again, I really appreciate your help...it's good to have people like you wiling to help specially for a small business like ours,
    Oscar.
    Apr 2008
    11
    Our machine's working no problem, we were within .050
    Thanks again for your help
    Jun 2004
    236
    You can get it dead center by simple parameter adjustment, All It does is give a final count on final approach after it reads the zero notch in the encoder
    I would have to look up the parameter
    Wayne
    Apr 2008
    11
    Thanks Wayne...haven't been on in a while but The machine still of .050 and working fine but if you can find the parameter number I'd appreciate it much,
    Oscar.
    https://www.yaskawa.com/pycprd/looku...-C843-7.25.pdf
    This should be the download link for the manual, it is available for free from Yaskawa Electric I looked for a few minutes, and Im relatively sure its in the 6000 area, and I dont want to appear rude, but I am not going through 100s of pages tonight. This should get you close.
    Jan 2015
    42
    Adjust prm 6304. Make sure after you change the value that you power off/on. Control reads new value on bootup
  1. Motor encoder alignment
    By danSN in forum Servo Drives
    Last Post: 03-05-2019, 10:21 PM
  2. Axis Alignment
    By WB-1 in forum DIY CNC Router Table Machines
    Last Post: 04-12-2012, 07:35 AM
  3. Encoder alignment
    By John_B in forum Cincinnati CNC
    Last Post: 10-04-2011, 12:44 AM
  4. Y axis pre-alignment
    By luizdiefenbach in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2011, 02:24 PM
  5. Mori SL3-H Turret alignment
    By JL Fabrication in forum Mori Seiki lathes
    Last Post: 07-24-2009, 02:26 AM
