586,655 active members*
2,359 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > open pocket 2d milling
Results 1 to 13 of 13
    Dec 2011
    94
    do you always have to extend the open side of the pocket so the cutter will come completely off?
    Apr 2009
    3376
    Re: open pocket 2d milling
    dashed lines will allow the tool path to come off
    simple example,I will do in V25 as I do not know what you are using,One tool path with advanced rough and one with adaptive rough/both 2D pocket
    Attached Files Attached Files
    Jun 2006
    143
    Jrmach,
    How come in your examples the tool paths curve outward after they clear the edge of the part instead of going straight out. You don't have a fillet to follow around the edge so why in the world would it do that?
    Apr 2009
    3376
    Your seeing the cutter comp being applied.?????I think
    Sep 2009
    105
    I think it's just a series of lead-ins. It makes a little more sense to me when you see it cut or watch the simulation.
    Apr 2009
    3376
    Turn off system comp. for the finish pass and it straightens the path for the finish pass.
    The roughing passes you don't have that option.
    Apr 2008
    1577
    Quote Originally Posted by Malish View Post
    Jrmach,
    I haven't looked at the file but it's probably "rolling" the cutter around the edges. Like a leadin/leadout. It keeps the cutter in contact with the material at all times.
    Mar 2012
    1570
    "do you always have to extend the open side of the pocket so the cutter will come completely off?"
    No, but there are times where creating an offset of the part profile creates a better result,allowing the user to set how far off the part the tool starts. Looking at the "strip" of parts you are making, using a profile with side roughing may make more sense.
    1) You will force the tool to start off the stock,
    2) You can edit your lead in, so the tool rolls into the part ( better for the tool )
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2009
    3376
    Thread Title "open pocket 2D milling"
    One of my Favs from a few years ago.High Speed Pocketing V23
    https://www.youtube.com/watch?v=ATkj...ature=youtu.be
    Mar 2012
    1570
    "do you always have to extend the open side of the pocket so the cutter will come completely off"
    No you do not... By default the software will start off the part by the radius of the cutter +. At this time I am not sure of the default additional offset value, I know it's hard coded and I am not sure what we set it to. If you need more clearance you would need to offset the geometry yourself.
    Attachment 244758
    As you can see in this screen shot of your part, the yellow is the offset for half the cutter, the purple is the center line start point off the part.
    I think the area you are concerned with is this spot:
    Attachment 244760
    In this example we have a 3 sided open shape, which can be problematic due to the "rolling" around the edge... Yes you may need to edit your wire fame to "adjust" the way the tool path is generated for a more appropriate result.
    In your example you have the lead set to ramp in.
    Attachment 244762
    You notice there is no "ramp" in the tool path, The tool just plunges in... Why? Well an open pocket is designed to work from the outside in starting off the stock. The dotted line are representing the "edge" of the part or the "edge" of the stock where the tool can plunge to depth and work it's way in.
    In your example you are cutting a strip of parts and the boundary you have setup would cause the tool to plunge in the material.
    This is what I think your setup would look like.
    Attachment 244768
    A different way to use the open pocket would be to create a 2 sided open.
    Attachment 244770
    Al DePoalo
    Mar 2012
    1570
    You could even make it a single side open pocket forcing the tool to start off the part on the left and just clearing the material over the shoulder.
    Al DePoalo
    Apr 2009
    3376
    Al,are you replying to a particular question that is not on this thread?Did the OP provide a file that I am not seeing ?
    Mar 2012
    1570
    You are right, the file is the wrong file.... It was sent to me by a customer and referenced a thread. This was not the thread. My bad.
    Al DePoalo
  1. V26 Open Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 03-23-2014, 08:55 PM
  2. V26 Open Pocket problems
    By Hood in forum BobCad-Cam
    Last Post: 01-06-2014, 10:42 PM
  3. Milling an open pocket
    By mark123 in forum MetalWork Discussion
    Last Post: 04-06-2012, 10:08 PM
  4. open pocket
    By camtd in forum Mastercam
    Last Post: 08-07-2007, 08:24 PM
  5. Open Pocket
    By camtd in forum EdgeCam
    Last Post: 10-23-2006, 07:09 PM
