586,598 active members*
3,565 visitors online*
Results 1 to 11 of 11
    Jul 2014
    7
    Exclamation puma 2000sy Turret issue
    I have recently change my puma 2000sy battery ( 3.6 volts) and now the turret doesn't take the good position. Ex. I tell to go to the second one , it will go to the fifth one.
    Does anybody can help?
    Jun 2004
    511
    Re: puma 2000sy Turret issue
    Sounds like you need to re enter the drive parameters. The blue book with the back-up data should have what you need.
    Jul 2014
    7
    Is it possible to get this information via internet?
    Thank you!
    Jul 2014
    7
    Is it possible to get this information via internet ? Since we don't have the blue book.
    Thank you!
    Jun 2004
    511
    The blue book is the master parameter set that came with the machine. Dosan has a tech that helps people on this site, post your problem in the Dosan forum and he will help you.
    Jul 2014
    7
    Do you know how to reset it to zero?
    Thank you.
    Jun 2004
    511
    There are a group of parameters that need set. dhardt is a member here he is a Doosan tech who normaly helps out, he must be on the road. Try to Call Doosan Service if you need to discuss further. EST = UTC-5
    (973) 618-2500
    Feb 2013
    788
    Did you replace a battery on a Pro-Motion/Vision drive...? or a Fanuc drive?
    If Pro-Motion/Vision drive:
    The Blue Book (Usually located in the door's pocket of the electrical cabinet) has a PMC section has a section that describes how to reset Parameter 8 of the drive to tell it what station it is currently sitting at.
    The side of the list describes setting Org.S (Origin Set) (but it looks like Or9.5 in it's LED form)
    If you have that instruction - follow it. If you don't have it, I will be back in the office (I was replacing a spindle on an H100) in the morning... (973) 618-2461 after 8:30EST
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jul 2014
    7
    Now it is good but it doesn't clamp , do you know how to make it clamp thank you!
    Feb 2013
    788
    Are we having two conversations?
    Is this also the same machine? http://www.cnczone.com/forums/daewoo...selection.html
    Feb 2013
    788
    If these are two different conversations, try following the instructions from the thread. http://www.cnczone.com/forums/daewoo...selection.html
  1. Daewoo Puma 230 Turret issue
    By atscnc in forum Daewoo/Doosan
    Last Post: 02-04-2022, 01:53 AM
  2. PUMA 2000SY TURRET PROBLEMS
    By VALBYRNES in forum Daewoo/Doosan
    Last Post: 05-16-2014, 05:41 PM
  3. PUMA 2000sy VS PUMA 2100sy
    By GreggC in forum Daewoo/Doosan
    Last Post: 10-03-2013, 11:51 AM
  4. Daewoo Puma 2000SY
    By asweeting_ in forum Daewoo/Doosan
    Last Post: 08-07-2012, 06:22 PM
  5. Daewoo Puma 2000SY, what CAD/CAM
    By mroy0404 in forum Daewoo/Doosan
    Last Post: 08-13-2009, 12:35 AM
