587,887 active members*
3,196 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Need some brainstorming on sluggish M700V control for retrofit
    Jan 2011
    350
    Hi guys,
    I have a vertical lathe that I'm currently retrofitting with a M700V Mitsubishi control. For some reason the HMI program runs at an extremely sluggish speed. Looking at task manager you can see that the HMI program goes in not responding status for long lapses of times every 30 seconds or so.
    In summary, for now I:
    Quintuple-checked the wiring
    Checked that all voltages are OK
    Swapped the DX771 unit and DX771 was found to be perfectly working
    Removed the DX121 and DX111 Remote I/O units just to check if it could be cause for the slowness
    Formatted the RAM
    Reloaded the ghost to the HD that I did upon receival of the product
    Loaded a ghost from another HD for the same control series, same result
    NC unit was tested to work perfectly on another M700V system
    Tried swapping G301 LAN cable, same result.
    Isolated the NC unit with the DX771 unit, the HD and the screen and PC unit, same result.
    Also because of this bug whenever I reload back system data and all, it works unless there is the "not responding" freeze, this causes an error.
    I'd like some brainstorming on thoughts of what could be the cause of this to try new ideas.
    Thanks.
    I guess there's OPI's G018 cable left to try with a swap, else there's only screen & PC unit left unless someone has another ideas...
    Jan 2011
    350
    Re: Need some brainstorming on sluggish M700V control for retrofit
    Just as information, that G018 cable was the cause of the issue and was replaced by a new one last week. Cheers.
  1. Old control retrofit
    By joe120 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2013, 04:03 PM
  2. control retrofit, which one
    By chaz6966 in forum Cincinnati CNC
    Last Post: 11-04-2010, 10:32 PM
  3. Brainstorming: 8x12 (8x14) Milling attachment
    By TroyO in forum Mini Lathe
    Last Post: 11-10-2009, 11:32 PM
  4. Sluggish Keyboard Jogging
    By nelZ in forum CamSoft Products
    Last Post: 10-20-2008, 08:42 PM
  5. Brainstorming on how to MFG a part
    By laka in forum MetalWork Discussion
    Last Post: 12-04-2006, 03:22 AM
