586,983 active members*
4,032 visitors online*
IndustryArena Forum > MetalWorking Machines > Colchester Tornado lathes > Tailstock Advances prevent spindle turn
Results 1 to 7 of 7
    Jan 2011
    Hi All,
    We have a Colchester Storm/Tornado CNC 300. When trying to use the tailstock, the spindle won't turn when tailstock advance.
    Does anyone know what's causing this? We bought this machine used. Not sure if previous owner has set some parameter to prevent crashing spindle on tailstock. This makes the tailstock useless.
    Please help..
    Ray
    Jun 2010
    4256
    Re: Tailstock Advances prevent spindle turn
    Um ... I fail completely to understand WHY you would want to move the tailstock while the chuck is running??????
    Cheers
    Roger
    Jan 2011
    Just to clarify.....we were trying to use the tailstock to run a long part. When we extended the tailstock, the spindle refused to turn. When we retracted it all the way back, then the spindle can turn again. We are buffled...
    Oct 2014
    It is written in the ladder best way extend tailstock fully and then back off slightly. on some of them there is a red line
    Sep 2013
    Hi riemanl,
    I saw your year 2011 request for help for the spindle not turn when tailstock advanced problem. Hope by this time you got a solution. I am experiencing exactly the same problem for my Colchester tornado A50 lathe with Fanuc 21i-T control. When a long job held in chuck and supported with tailstock centre and tried to run, the following message comes up.
    "spindle won't start with t’stock in". The same program can run with out any issue, if the tailstock is not used. Could you or somebody knows a solution for this please help!!!!!
    Ven
    Jun 2010
    4256
    First solution: shoot the tailstock.
    Second sol'n" shoot the fanuc.
    Does the Fanuc even KNOW where the tailstock is??? If so, ... can you fake the switch?
    Cheers
    Roger
    Sep 2013
    Ha ha ha...... I tried the first solution, extending the tailstock maximum until the red mark is visible. It worked just once. Then again the message "spindle won't start with t’stock in" comes up. Will there be any parameter setting to be changed???
    Ven
  1. Replies: 2
    Last Post: 01-13-2017, 09:03 PM
  2. Anyone used sub-spindle as tailstock?
    By TonyW in forum Okuma
    Last Post: 09-01-2015, 06:29 PM
  3. Okuma using Sub spindle as Tailstock
    By crandalljclj in forum Okuma
    Last Post: 03-11-2013, 10:11 PM
  4. How to program sub spindle as a tailstock
    By RMW in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-19-2012, 01:38 AM
  5. Tailstock Advance on Hitachi Seiki Hi Tec-Turn 23SIII
    By Bob Dolan in forum Mori Seiki lathes
    Last Post: 05-10-2011, 04:51 PM
