586,734 active members*
2,474 visitors online*
    Dec 2011
    Redsail x700 laser
    Hi I have just got an redsail x700 laser from redsail in china didn't know how to set it up but found someone to line mirrors and lens up done test everything was ok but know it could run for 7 mins at speed of 20 power at 65 cut 4mm mdf temp not going above 17 then I switch it off go back to the machine 2 hours later ask it to do the same thing and it will not do it it has reduced power laser beam is not as bright will not cut at even 85 power and speed 6 but leave machine till the next day it does the same thing everything is lined up properly redsail saying I have made wrong adjustments I have not made any adjustments can someone please help
    Kind Regards William
    Sep 2014
    21
    Re: Redsail x700 laser
    Hi william. I was just wondering if you managed to sort out this problem and if you are otherwise generally happy with the machine?
  1. RedSail X700 60W Laser not firing
    By ajmcmullin in forum Redsail Laser
    Last Post: 06-11-2016, 08:52 PM
  2. Problem with Redsail X700.
    By dany1914 in forum Redsail Laser
    Last Post: 11-29-2013, 04:39 PM
  3. Redsail X700 arrived
    By John Thomson in forum Redsail Laser
    Last Post: 09-19-2013, 12:20 PM
  4. Replies: 2
    Last Post: 05-21-2013, 05:52 PM
  5. x700 redsail laser cutter
    By Mannetjie Both in forum Redsail Laser
    Last Post: 03-11-2013, 05:50 PM
